| diyAudio Sponsor | ||
ciao
my idea is Reverse standard Single Ended Push Pull just to have input and output in ground level and put a low ratio transformer on big power tube |
#2 | |
The A Number One problem with all SEPP-like designs is that they are balanced for one specific load impedance. Let the load change (and speeks are anything but a constant load) and it goes out of balance with rising distortion. |
#3 |
Hi
SEPP configuration don't need splitter (there is a virtual active load) is like OTL configuration (Camorani's design) http://www.audiodesignguide.com/otl/otl_s_page3.tif normally used for preamplifier in this case with transformer http://www.icl.co.jp/audio/english/k-mt.htm the load change and also the local feedback see this: http://www.audiophonics.com/audiopho...c33c-pp-1.html Best Regards |
#4 |
Your schematic doesn't show a SEPP, it show a cathode follower output stage with active load.
A SEPP is unbalanced, the upper part is a cathode follower and the lower part is a normal cathode grounded amplifier. The SEPPs that have been made commercial, (like Philips with EL86) give a lot of 2nd order distortion, ~10% The Camoroni document is full of unsubstantiated claims about output power etc. A SEPP without phase splitter can only work in class A meaning that the output will be very low. http://www.audiophonics.com/audioph...6c33c-pp-1.html There is nothing about SEPPs in this link. Best Regards Hans |
#5 |
there is a topology called PPP (push pull parallel) - just don't happen to have a schematic around. In this, two cathode followers are driving an output transformer. I built it and it sounds pretty good actually.
will try to find a schematic and post.... |
#6 |
Thanks for your reply
may be the discussion is about name of architecture, i'm wrong i would like to focus quality of sound not the power or rendering my idea is concentrated on benefits in pure complementary configuration, especially in class A, like this drawing the link of Susan Parker show how is good have load on cathode in particular to have local NFB (she named this "zero feedback") |
#7 |
What you have drawn is just series connected cathode followers which means that the total gain from input to the output cathode will be less than 1. Maybe you intended to draw series connected SEPP or SRPP stages, the difference is then that the input is the lower grid and the output is the upper cathode on each stage.
However A SEPP doesn't work as if it would be a complimentary configuration even if if it look like that, the SEPP is inherently unbalanced as has been described before, (the gain of the lower and upper tube are different). The way to provide a complimentary function where both the upper and lower tubes provide same gain is to introduce drive to both tubes and a gain compensation method whereof the Futterman connection is the most well known although there are several others. How Susan Parker can call a cathode coupled stage, (that have infinite feedback) as zero feedback is interesting in itself but it is of course nothing new to use a cathode follower output stage. Regards Hans |
| Yamaha - Natural Sound System - Model CA-700 | Greg Erskine | Solid State | 6 | 3rd June 2011 04:10 AM |
| Yamaha R5 natural sound receiver | OneyedK | Analog Line Level | 2 | 26th December 2007 10:12 AM |
| The sound of... tubes ! | Cobra2 | Tubes / Valves | 65 | 1st February 2007 08:40 AM |
| Yamaha A-760 of the Natural Sound range | Layberinthius | Solid State | 0 | 21st March 2004 11:06 PM |
| Page generated in 0.09687 seconds (79.84% PHP - 20.16% MySQL) with 11 queries |
