Front Panel Express finishes - Page 2 - diyAudio
Old 29th January 2008, 04:44 PM   #11
JoshK is offline JoshK  Canada
I am building the Karna as well... I find it interesting that you are doing one PSU chassis. I've thought about that as well. I am not quite ready to do the layout yet, my PSU transformers should arrive in a week or two (ordered from Onetics).
Old 29th January 2008, 05:49 PM   #12
zigzagflux's Avatar
O_O
Let me know how you like them. I am considering O-netics for the output transformers (digs deep into pockets).
I will say, however, I am very happy with the Electraprints. They are extremely quiet, in comparision to the typical Hammonds, and have very good (5%) regulation. Beefy trannies.
Old 31st January 2008, 06:55 PM   #13
jrebman is offline jrebman  United States
Any advice on powder coating an aluminum top plate? I need a deep red/burgundy top plate to use on a gold tone Koa base, and the only way I'm going to get the color I want is either custom powder coating or car paint. Should I go for the raw aluminum, or something clear anodized. Will the powder coating heat destroy a chromated finish on the underside?
Thanks,
Jim
Old 31st January 2008, 07:37 PM   #14
zigzagflux's Avatar
No. Power coating is an electrolytic process, and doesn't require heat. You can actually tape the areas you don't want coated, and put the plate through the process. Pull the tape off when you're done. I would think this would work just peachy.
Old 31st January 2008, 07:49 PM   #15
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
every powder coating process I've ever seen has a baking step where the powder is permanently adhered after spraying the powder.
Old 31st January 2008, 08:07 PM   #16
BudP is offline BudP  United States
BudP's Avatar
zigzagflux,
At the risk of irritating Josh, Jack at ElectraPrint is probably as good as you can get for power.
PM Lynn Olson for his current view of the filament situation for the DHT's. We do have filaments powers with near absolute balance between halves of the secondary windings and extremely good shielding. Josh will get his in about a week and can report.
O-Netics is as good as you can get for the audio output transformers. This includes the interstage devices.
Tribute is still the best sounding input splitter transformer, but very costly. Sowter has a very good unit also. When I get to i,t we will also have a very good input splitter, based upon the preamp outputs we have.
Lundahl has some very good small signal transformers that can also be used as input splitters.
On a different note, all transformers are going up in price pretty dramatically. Materials pricing has doubled for all items, with one material having risen by 1700% in 4 years (M6 core) and the copper base price up 400% in 2 years. Not an excuse here, just a warning of what to expect.
Bud
Old 31st January 2008, 10:10 PM   #17
zigzagflux's Avatar
Being this is my thread, I guess I can threadjack a little. If it goes anywhere, I could start another thread.
Thanks for your reply, Bud. It is an honor to have you provide advice.
That is comforting. I want the best that I can afford, and Jack's prices, while high, were justified given the quality. I ordered shielded trannies, too, because I know how you and Lynn feel about shielding and keeping heater supply separate from power supply, which is what I did. O yes, I definitely read and take your(s) advice.
I will do that; at the risk of getting flogged with boos, I have already built and tested 4 regulated DC supplies for the output stage. But I am always open to try, if the benefits of AC outweigh the annoying hum. Was careful to use split bobbin transformers and common mode chokes; we shall see.
I believe you. I have not yet bought the iron for the amp proper, as there are a few paths of the design I am considering. However, you will definitely be considered for the iron. Lundahl's 1620AM would be your competition with me. Kevin at K&K is a great supplier of iron, service, and moral support.
You ain't kidding. Even more surprising is the fact that most mining company stocks are in the toilet. Patience, patience.
front panel push-button pred Parts 15 9th August 2008 12:21 AM
Front Panel / Enclosure Help tumler Parts 8 7th August 2007 09:41 AM
Front Panel Manufacture Bonsai Parts 5 21st December 2006 04:01 AM
DIY Front Panel !! udip Solid State 12 16th January 2005 07:37 AM
Aluminium for front panel jouch Solid State 7 15th March 2001 11:51 PM
Copyright 1999-2017 diyAudio
