diyAudio Sponsor
Old 25th January 2008, 05:11 PM   #1
bigwill is offline bigwill  United Kingdom
Question Single stage preamp
Quick question - I just ordered the bits required to make a Gary Pimm battery biased CCS, and I was wondering if it's possible to simply use a CCS loaded 6SN7 as a single stage preamp - each half as a channel. Would this arrangement work and be able to drive cables / input stages?
Old 25th January 2008, 05:34 PM   #2
SY's Avatar
It depends on the cables and the load. Assuming there's no cathode degeneration in the 6SN7 circuit, the source impedance will equal plate resistance. For usual operating conditions, that will be between 7-10k. That's pretty high. If your power amp has a high input impedance (more than 100k) and the cables are short, you can probably get away with it.
If there is cathode degeneration, that makes things worse; the effective plate resistance will be increased by a factor of 21 times the unbypassed cathode resistance.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 25th January 2008, 05:42 PM   #3
I see. I sort of got it into my head it would be able to swing roughly the bias current into the load if needed - if only things were that simple. I guess I'll be using a cathode follower!
Old 25th January 2008, 06:14 PM   #4
dsavitsk's Avatar
Or you could just choose a more appropriate tube for the job. Same topology, but with a 5687, will give you roughly the same gain and a Z out of about 2 to 2K5. A 12B4 will give you less gain (which might be a good thing) and an even lower Z out.
http://www.ecpaudio.com
Old 25th January 2008, 06:19 PM   #5
Oh neat, it's possible - are there any suitable octals that would also work?
Old 25th January 2008, 06:31 PM   #6
DougL is offline DougL  United States
6H30 Octal
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 25th January 2008, 06:43 PM   #7
Hmm, the 6H30 does look awesome but it seems expensive!
Old 25th January 2008, 06:49 PM   #8
diyAudio Moderator Emeritus
ray_moth's Avatar
Maybe a mu-follower would be better for your needs? It would use both halves of the 6SN7 (or other double triode), would give practically the same linear performace and gain as a CCS load and would have the low OP impedance of a cathode follower.
The biggest advantage, though, is that you wouldn't need to use the Gary Pimm CCS, so you could save it for another project.
Old 25th January 2008, 06:59 PM   #9
Sounds like a good idea to me!
Old 25th January 2008, 07:09 PM   #10
Hold on - If I use the mu-output of Gary Pimm's battery CCS won't that basically achieve the same thing?
5687 as a single stage SE amp simonov Tubes / Valves 4 15th November 2006 09:26 PM
Single FET line stage wleediy Solid State 12 6th July 2004 06:18 AM
Single Stage power amp. lumanauw Solid State 10 2nd April 2004 09:03 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Single stage PWM amplifiers. Rhesus Solid State 3 14th February 2002 03:56 PM
Page generated in 0.09863 seconds (75.98% PHP - 24.02% MySQL) with 11 queries
