6as7g Se
6as7g Se
Old 17th June 2008, 02:03 AM   #11
Akita is offline Akita  Malaysia
Hi Shoog, I found your tread about 2tube pp 6as7. It is very interesting too.
Alexq, the 6080 parafeed amp? is single ended or push-pull?
It is something like the schematic below?
Old 17th June 2008, 05:32 AM   #12
alexg is offline alexg  Philippines
alexg's Avatar
Akita, parafeed amps are single ended.
I don't have a schema of my amp and my amp is on loan to a friend, I will draw one when I get it back.
Old 17th June 2008, 08:43 AM   #13
SemperFi is offline SemperFi  Wake Island
The Lilliput wont drive the 6AS7 to full power, the preamp tube will clip first.
You'll need about +-125volts peak drive voltage and the latter circuit with the choke loaded driver will do that much better.
6AS7s may not be the most linear, but they are still the most under rated power triode out there. Perhaps the low rp and thus low winding ratio in the O.T. makes up for it's faults, b/c it certainly sounds great.
Old 17th June 2008, 09:53 AM   #14
Shoog is offline Shoog
Shoog's Avatar
I love it - but in PP. My PP effort sounds very SE in characture.
Shoog
Old 18th June 2008, 06:30 AM   #15
Alexq, How many power output you get for you Se parafeed amp?
Old 18th June 2008, 08:54 AM   #16
alexg's Avatar
Akita, I have not measured the power, but I have estimated between 2.5 to 3 wpc.
6as7g SeHide this!Advertise here!
My 6AS7G Fuse Link Checker Zero Cool Tubes / Valves 0 11th October 2008 03:47 PM
6AS7G Grid Voltage ?? Zero Cool Tubes / Valves 2 23rd May 2008 08:04 PM
6080 / 6AS7G power amplifier cjng74 Tubes / Valves 1 16th September 2007 01:17 PM
6AS7G with grid current? Wavebourn Tubes / Valves 1 16th November 2006 11:22 PM
Filament of a 6AS7G GF Tubes / Valves 7 8th April 2004 05:43 AM
