diyAudio Sponsor
Old 24th January 2008, 11:07 PM   #1
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Default Formula question
Ok just have a quick one.
The formula 1/2piRC= -3db point
The question I have is do I put in the capacitance is the value in farads or microfarads.
If the value is farads is the answer to the formula in hertz ???????
Thanks for the help.
Nick
Old 24th January 2008, 11:14 PM   #2
Sherman is offline Sherman  United States
The C is in farads and the answer is in hertz.
The formula I have in my "useful formulas" spreadsheet-
1/(2*Pi*R*C)*1,000,000
That way I can put the value in in microfarads since the spreadsheet is designed to use "real world" values and the formula converts it for me.
--Sherman
Old 24th January 2008, 11:28 PM   #3
SY's Avatar
C in farads, R in ohms. Or R in megohms, C in microfarads. Both give you the answer in Hz.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 25th January 2008, 12:12 AM   #4
nhuwar's Avatar
Gracias
Nick
Old 5th February 2008, 12:12 AM   #5
nhuwar's Avatar
Wait a sec I missed something before if you use microfarads and megohm is your out come in megahertz?
Nick
Old 5th February 2008, 12:44 AM   #6
Hi
As SY said, the answer is still in Hz.
The F unit is divided by 1000000 to obtain microF. This 1000000 is multiplied with the R, to obtain the megaR.
100k is 0.1M (ohm).
100nF is 0.1microF.
and so on...
Good luck, Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 5th February 2008, 12:45 PM   #7
nhuwar's Avatar
Ok I was just making sure. I was getting some werd results thars all. I think my problem was I was thinking high pass instead of low.
Nick
Old 5th February 2008, 02:46 PM   #8
richwalters's Avatar
Reminds me of the early days when a 1mfd marked cap was actually 1uF in disquise ! some dreadful mistakes were made. A true 1mfd cap is quite a different animal.
SY remember this ?
r:-
Old 5th February 2008, 04:43 PM   #9
SY's Avatar
Yes, indeed. Especially on cheesy paper caps (which are now all the fashion rage).
Sadly I'm also old enough to remember mmf. And cps. I remember that QST, in one of their April issues (maybe 1967, 1968?), published a nomograph for cps to Hz conversions.
Old 5th February 2008, 05:02 PM   #10
kevinkr's Avatar
I was about 9 when Batman first hit TV (1966?) and I too still remember cps, mmfd, and the physical components themselves - the electrically leaky wax covered paper things that often passed for capacitors, and those terrible carbon composition resistors with a tolerance of 20%, which always seemed to be way off the mark..
www.kta-hifi.net
box formula crs1 Multi-Way 29 23rd January 2008 09:53 AM
Q formula PeteMcK Multi-Way 10 17th January 2008 07:42 PM
Question on L-pad theory/formula leadbelly Multi-Way 8 19th January 2004 05:39 PM
Need help on x-over formula Jay Multi-Way 3 12th August 2003 05:28 PM
Anyone have the formula for... Rino odorico Multi-Way 4 22nd January 2003 04:07 PM
Page generated in 0.09802 seconds (79.74% PHP - 20.26% MySQL) with 11 queries
