diyAudio Sponsor
Old 24th January 2008, 05:45 PM   #1
jackinnj's Avatar
Default 6922 -- curing the ultrasonic RIAA blues
For the most part this phono stage is within tight tolerance, but I was troubled that the response rises so much after 20kHz -- not that there is that much information on vinyl save for the fact that a "snap, crackel or pop" will overload the next stage. It takes way too much additional Cgk to tame the ultrasonic response -- or is it OK, or should I even worry as the nominal response is down ~ 20dB at 20kHz vs 1kHz?
Old 24th January 2008, 05:50 PM   #2
PigletsDad's Avatar
The question is actually which RIAA curve you want to follow. There is a recent fashion for stopping the rolloff at 50kHz, as the commonest cutting head stops the boost at 50kHz. My personal take is to say that a preamp should follow the standard, but the design that you have built has an extra component to limit rolloff in the ultrasonics.
R5 is the culprit. If you remove it, you will get the right curve, without using a compensation cap. Leave it in if you want ultrasonic boost relative to RIAA, to compensate for cutting head bandwidth limitations.
Old 24th January 2008, 05:50 PM   #3
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Too many rice crispies
The input capacitance seen by the cartridge is going to be humungous! Surely your rising 20kHz response is simply an indication that 1k is too big for the resistor below the 3200pF capacitor? As for worrying, yes, you're right to worry, excess ultrasonic response could exacerbate snap crackle and pop.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th January 2008, 06:21 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
SIMs and real life are very different realities.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 24th January 2008, 06:26 PM   #5
jackinnj's Avatar
The data in the graph are the actual results, not simulated -- I just used the Multisim schematic to illustrate the layout.
Old 24th January 2008, 06:43 PM   #6
RIP
pedroskova's Avatar
Edit...didn't see graph values.
Old 30th January 2008, 09:39 PM   #7
jackinnj's Avatar
With R5 = 625R -- (RED) -- and various other values
Old 31st January 2008, 02:31 AM   #8
ArtG is offline ArtG  United States
I've been following your posts on this circuit for some time, and I'm rather impressed with the results you've been able to achieve! So much so, that I'm seriously considering building it for one of my PAS units.
What values did you use for the violet trace in your last post? Looks good to me! It's essentially flat to 20K, and 1db down at 50K. I tend to think, from a practical standpoint, that this would be preferable to a rising HF response. I have just two questions..... Is R10 calc'd for a certain following load (volume control), and... how does it sound to you?
Thanks!
Old 31st January 2008, 11:32 AM   #9
jackinnj's Avatar
The magenta trace is 1k//1k = 500R.
I have no idea how the circuit will perform over time -- the anode follower and its components might be very sensitive to tube aging, and all I have done so far is assemble the RIAA amplifier -- it hasn't gone live with vinyl yet.
Adjusting the value of R6 tilts the curve a bit clockwise -- which makes the deviation from RIAA even lower.
I have some cases for the preamp and its power supply -- have been busily rewinding a transformer to fit in the case -- this will use the LR8N3 as localized regulators.
Old 31st January 2008, 03:28 PM   #10
jackinnj's Avatar
The top trace is the RIAA preamp with LED's in both cathode positions, R5=625R, R6=201K
The two lower traces use 200R bypassed with 1,000u -- the magenta is the stock kit, the blue trace places 625R at R5 and 198K for R6. In the original R5 is 1K and R6 is 220K
Ultrasonic Cleaning?????? grhughes Tubes / Valves 25 7th March 2009 01:31 PM
Higher than 22k, or ultrasonic? jahhn Multi-Way 34 2nd October 2007 09:43 PM
Ultrasonic heaters DHT112A Tubes / Valves 53 10th June 2006 11:59 AM
ultrasonic sensors sss Everything Else 4 16th May 2006 02:42 PM
Broadcast RIAA Blues wrenchone Solid State 8 21st February 2004 12:55 AM
Page generated in 0.10573 seconds (80.38% PHP - 19.62% MySQL) with 10 queries
