| diyAudio Sponsor | ||
Hi all,
I am exploring the World of interstage / signal transformers, especially as phase splitters. Cheap-skate as I am, I wonder if there are good alternatives for reasonable money ? But apart for the financial investment, I thought of the ways to connect an interstage, see attachment. I wonder if my assumptions are correct ! Option one; No need for a coupling cap (which is a good thing) but risk of core saturation due to DC in primary coil (especially when using cheap iron) Fidelity depends on quality of transformer Option two; Saturation-risk greatly reduced as DC is blocked from primary coil, by reintroducing the coupling cap. Fidelity depends on quality of transformer and quality of coupling cap. Option three; Transformer used as single coil, a centre tapped choke actually. Need for coupling cap, and compensation for resistance in coil for the inverted signal. Fidelity is affected by the coupling cap and matching the signal-level through series resistor, but not by the quality of the transformer. One should watch for a possible low pass filter created by the values of the coupling cap and the induction of the coil. Please correct me where I’m wrong !! Cheers, Empee
In the end, all is good If it's not good, it's not the end |
#2 |
Empee,
I don't have a lot of experience with transformers as phase splitters (or for that matter phase splitters in general) but I just completed a PP EL84 amp using autoformers as the phase splitters. This is most similar to your option 3 but cleaner in practice than your posted schematic. It does require a coupling cap. I purchased the autoformers from Electra-Print. Jack designed the specifically for this purpose. They work extremely well and the amp sounds very good. IIRC they were about $56 US each. It isn't the cheapest solution. A tube phase splitter can be done for less but with the accompanying issues of additional wiring, power supply considerations including heaters etc. This autoformer solution is very clean. I've attached the schematic.
--Sherman |
#3 |
lookin' good !
power of simplicity I really like to know, in the way your transformer is coupled, (same as my Option 3), how much the fidelity depends on the quality of the iron, since you're basically only using the coil... ...or am I completely wrong in this !? Cheers, Empee
#4 |
Empee,
Also inexpensive is to phase split at input. I have had great luck with the Edcor WSM10K/10K at $10 each in the U.S. I know there is an Edcor European distributor which could be in your home country. I usually direct couple to the push-pull finals from input to save on the cost of a pair of caps, like here Matt |
#5 |
[QUOTE]Originally posted by Empee
[B]Hi all, :::Option one; No need for a coupling cap (which is a good thing) but risk of core saturation due to DC in primary coil (especially when using cheap iron) Fidelity depends on quality of transformer:::: although not shown in your schematic as drawn--- this arrangement does in fact have (in 99 percent of apps) a capacitor in the signal path. The last cap in your power supply is clearly in the signal path--- and almost always will be larger in value than a blocking cap as used in a properly designed parafeed application. ::::Option two; Saturation-risk greatly reduced as DC is blocked from primary coil, by reintroducing the coupling cap. Fidelity depends on quality of transformer and quality of coupling cap.::::: to illustrate the point I make above--- in this drawing move the blocking cap from the top leg of the IT's primary and put it in the bottom leg to ground. this is the same spot where the capacitor is located as in drawing #1. but it will likely be much smaller in value. Other benefit is that (instead of the plate load resistor as shown) you can use a C4S or large plate choke in place of the anode loading resistor--- and get much better power supply rejection. :::Option three; Transformer used as single coil, a centre tapped choke actually. Need for coupling cap, and compensation for resistance in coil for the inverted signal. Fidelity is affected by the coupling cap and matching the signal-level through series resistor, but not by the quality of the transformer.:::: several thoughts here. In this discussion we are treating the phase splitting autoformer generically--- but much depends on the actual design quality of the device not on a generic analysis---- for example--- the two halves of the autoformer phase splitter can have identical DC winding resistance btwn the two halves. And the design can be arranged that the capacitive reactance btwn the two halves is largely identical. And if the two half windings (driven vs induced) are interleaved you can have very high degree of coupling btwn the driven half and undriven half windings. Recall--- that in say example #1 and #2 we must have tight coupling (i.e., controlled leakage L) btwn the primary and secondaries to get good results. the autoformer phase splitter can likewise be interleaved to promote greater coupling. In a unit that we make the amplitude differential (the output from the two windings) at 20khz is less than two tenths of a db. Not so bad at all--- I'd say. ::::One should watch for a possible low pass filter created by the values of the coupling cap and the induction of the coil.::::: you also have to watch out for theis "low pass filter" in any design where you have a capacitance and an L. Your example #1 will have a resonance from the L of the tran's primary and the last cap in the power supply interacting with each other. The trick and goal is to get the resonance well outside of the audio band. You did a nice job in graphically laying out your options. the only other advice I'd offer is that in example #3 you appear to have drawn say a conventional two winding trans and that one of the windings is unused--- your only using the center tapped winding--- the unused windings are very likely to hurt the coupling btwn the secondary halves (one driven--- one induced) since they are most likely interspersed btwn the primary. If your going to go with #3---- you really need to get a transformer that was designed from the ground up as a phase splitting autoformer. there has been a lot of discussion of autoformer phase splitters on our MQ forum over at Audio Asylum. Here is a schematic that I had put up on the MQ forum maybe a week or so ago. http://www.q-audio.com/images/el84amp2.jpg Mike |
#6 | |
Mike is correct, but you could try this as a way to eliminate the large cap from the signal path and still use a single feed design. ![]() Obviously, the output stage as drawn is single ended, but you could do a push-pull stage instead without change to the driver. More info on the design at http://www.ecp.cc/SSS.html Also, you could make the driver differential with an input transformer: http://nutshellhifi.com/triode1.html
http://www.ecpaudio.com |
#7 | |
http://www.diyaudio.com/forums/showt...66#post1396766 the concern with this particular schematic as shown is that the resonance is at 50 hertz from the published specs for the trans and the size (1 mfd) coupling cap shown in the schematic. here is a really handy LC calculator--- http://www.opamplabs.com/cfl.htm with a 1 ufd blocking cap your primary L of the driven half winding would need to be approx 253H to get the resonance down to 10 hz. alternately, with a 10H inductance the C would need to be approx 25 uf to get the resonance down to 10 hertz. MSL |
#8 | |
Doing your phase splitting at the front end is by far the cheapest option. Shoog |
#9 | |
Hi !
Thank you all for the replies! Quote:
Yes, that's the idea... I got a couple of Hammond 124A's from wich I really doubt they are any good. But as I was thinking; if I connect the 'formers as in option #2 or #3, I'd probably get the best fidelity since I'm not putting stress on the iron as in DC terms. But I am still wondering how much the reactence half of the sec. winding is relying on induction from the iron core Less than options #1 and #2, I think Cheers, Empee
#10 | |
Electra-Print also has these same autoformers with an M6 core. According to Jack these are able to handle higher signal levels.
--Sherman |
| More Phase Splitting Questions | Sherman | Tubes / Valves | 17 | 29th June 2007 02:52 PM |
| Page generated in 0.14585 seconds (84.06% PHP - 15.94% MySQL) with 11 queries |
