g2 driven tubes
g2 driven tubes
Old 24th January 2008, 04:30 PM   #11
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Tom,
I respectfully cannot agree with your analysis of the g2 input range being decreased with less neg. g1 bias. You can always turn the tube off with lower g2 signal, so that end is not impacted. With less neg. g1 bias, you get more plate current for the same max. g2 signal voltage. So the upper end is extended, not compressed by less g1 neg. bias.
I do see you point about cathode biasing for stable idle current. But for a required idle current, this can be achieved with less neg. g1 bias and less g2 pos. bias. Plate instability sets in sooner if the g2 voltage is higher however. All theorizing admittedly, but I don't see anything wrong with my analysis.
Don
g2 driven tubesHide this!Advertise here!
EL84 driven 2a3 alexg Tubes / Valves 3 30th June 2008 12:27 AM
G2-driven 6BM8 wfmali Tubes / Valves 34 13th February 2008 05:47 PM
How is a ESL driven directly by tubes? ak_47_boy Planars & Exotics 3 6th November 2006 07:44 PM
Tubes driven by BJT's drago Tubes / Valves 12 12th April 2006 08:35 PM
sub not being driven enough? dlagace Subwoofers 3 25th November 2003 11:26 PM
