diyAudio Sponsor
Old 22nd January 2008, 09:16 PM   #1
Default Selecting an IT impedance
All,
What parameters do I look for when selecting an Interstage Transformer ? Mainly; I am unclear on how to select the secondary...Wouldn't you normally want the lowest impedance possible to the grid of your tube ?
The Primary impedance I understand completely...
Thanks !
Steve
Old 22nd January 2008, 09:35 PM   #2
Maybe this thread is helpful?
http://www.thaiavclub.org/forums/ind...sg%25msg_id%25
Old 23rd January 2008, 06:12 PM   #3
That helps a bit; but I am very curious as to the selection of the secondary impedance value. Again; I would think you would want the lowest possible value to drive your grid ?
Thanks,
Steve
Old 23rd January 2008, 06:16 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The highest with Miller capacitance in mind, unless you need a grid current.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 23rd January 2008, 06:46 PM   #5
Sir,
Thanks - but I am not quite sure how I need to compute this; as all I have would be the grid impedance value ?
Steve
Old 23rd January 2008, 07:04 PM   #6
Wavebourn's Avatar
Assume it as a capacitive load.
Old 23rd January 2008, 10:54 PM   #7
Hi, i think this impedance ratings for the secondary are only missleading for the purpose of using the IT to drive a tube.
Don't care about this, you need to know what is the anode impedance of the driver tube and see if the primary inductance is sufficient.
Unless you are driving A2 grids, i see no reason for stepdown IT, so turns ratio should be 1:1.
The driving impedance is the driver's impedance + the dc resistances of the windings.
If your driver of choice is e.g. an 6SN7, you can forget linear response down to 20Hz. Needed primary inductance is too high. Maintaining this would compromise linearity in the higher frequencies
Greetings
Konstantinos
Help selecting a DIY amp for... BlizzofOZ Chip Amps 1 30th April 2009 09:38 PM
Help selecting DIY amp for... BlizzofOZ Class D 2 29th April 2009 03:03 PM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
Help selecting an amp FBLEAGH Solid State 1 21st September 2001 05:00 PM
Page generated in 0.08447 seconds (72.34% PHP - 27.66% MySQL) with 10 queries
