diyAudio Sponsor
Old 22nd January 2008, 06:57 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default preamp get a hum when volume is at full or 80% is thier away to stop it??
preamp get hum when volume is at full or 80 % .even when thier
is nothing connected to the amp ill still get hum i know its the tube but iam not so sure on how stop it also if i keep the volume at 50% and hook up anther opamp again to make it louder the hum still can be heard is thier away get the hum to stop????
Old 23rd January 2008, 12:50 AM   #2
apassgear's Avatar
Most probably you have a bad pot but aside from that a 1M Ohm value seems quite high also, try a 50K or 100K pot.
You may try adding a shunt resistor to the wiper of the pot to minimize the noise but I doubt this will eliminate your problem
Old 23rd January 2008, 04:30 AM   #3
kevinkr's Avatar
I hope the op-amp circuit is not built as shown.. Feedback is always to the inverting input.. Plus as designed the input impedance of that op-amp as an inverting circuit is only 33K - doesn't work so well with a 1M pot. Use the non-inverting configuration with the gain you need instead that way you really have a 1M pot that is not loaded down. (The non inverting input should have an input impedance many times higher than the thevenin equivalent of the pot wiper at worst case of 250K.)
Given the miniscule currents in the 12AU7A at the low supply voltage used reducing the 1M pot to anything less than 500K would probably give bad results. You need additional shielding and make sure the pot body is grounded.
www.kta-hifi.net
Old 23rd January 2008, 03:44 PM   #4
i took the tube out still with the volume at the same leval still get the hum i also had 50k as 1m pot with the same results the case is ground
Old 24th January 2008, 04:52 PM   #5
i put on inverting input feedback work great for when nothing is connected to amp makes a whisle noise resistor are 820 to the ground 4.7k to the output and - side of the opamp
Old 24th January 2008, 06:38 PM   #6
kevinkr's Avatar
And the pot is connected to the non-inverting (+) side of the op-amp right?
Whistling as described sounds like another term for oscillation. The connections at the (-) input of the op-amp must be very short for good stability. A small cap - say 30pF - 100pF in parallel with the 4.7K feedback capacitor will compensate for higher than expected input capacitance if your layout is not so good. Finally make sure that you have a power supply bypass cap to ground right on the supply pins of the op-amp.
www.kta-hifi.net
Old 25th January 2008, 03:41 PM   #7
yes on the right thxs work great yes i have 10uf on the power pins and 10 ohm resistor connect to each power pin
Old 25th January 2008, 06:41 PM   #8
Alastair E's Avatar
In your above pre, the supply is 12V.....
You also have very high plate resistors, therefore very little current flow and need high value pot or the gain will suffer badly.
I have experimented with tubes at 12V and devised this gain stage followed by a follower that can supply a 100K pot fairly easily....
Das Beste Oder Nichts
Is setting an alps volume pot to the full position the same as bypassing? boidos Solid State 3 12th February 2009 07:57 PM
24 Steps Volume Attenuator (Dale Resistors-Full Balanced) YFW Swap Meet 24 25th July 2008 03:37 PM
max power for full volume? bob_v5 Multi-Way 7 21st February 2008 05:22 PM
How to stop web browser from unmuting and cranking up master volume on PC bzdang Digital Source 0 12th January 2006 03:20 PM
Help me stop my preamp from farting! Buckeye Sound Tubes / Valves 14 26th October 2005 02:21 AM
Page generated in 0.10460 seconds (80.43% PHP - 19.57% MySQL) with 11 queries
