| diyAudio Sponsor | ||
Dear friends.
I have a project circling around in my head. It involves an input transformer before 1/2 5687 and interstaged to 300b. I am looking for a 1:3 line input transformer that can also convert balanced signal to unbalanced. I have found the LL1676 that can be used as 1:2 IT. 1:3 is more difficult for me to find, and therefore I was wondering about the OPTs that http://www.sacthailand.com/ sells. The have a preamp output trannie which has the following data: L-531S (Model nr.)(With balanced out) 5.0K:600R 1:0.33 (is this the same as 3:1 ??) 15-75,000Hz http://www.sacthailand.com/Transformer_Interstage.html Is it possible to use this in reverse so that (in my head that is) it can be used as input trannie with 1:3 step up? And balanced to unbalanced possibility? Sincerely BTW. I am quite a novice in these aspects. |
#2 |
May I ask why you're needing a 1:3?
se |
#3 |
Take a look at the Cinemag CM-25101 it is 3.1:1 and should work fine in reverse. They are about $80 USD each,
http://www.ecpaudio.com |
#4 |
One problem you may encounter is hum pick-up. The signal levels in a line output transformer are high and hum pick-up is usually not an issue, so hum-bucking and shielding are not often used. When used in the input position, the signal levels are lower and hum may be a problem.
I ran into this when using a Jensen line-out transformer as an input to a 300B amp. It has a single-bobbin EI-core, and picked-up hum from a power transformer over 6 inches away. I cut a piece of square steel tubing (3" on a side) and mounted the transformer inside this. It cut the hum down by about 7dB, which was enough. A mu-metal shield or relocation of the transformer would be necessary for further hum reduction. The Lundahl transformers use a dual-bobbin C-core design, which is much better at rejecting hum, so you may not have a problem here. - John Atwood |
#5 | |||
HTH Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#6 |
A bit tight schedule right now. Thanks for the answers.
Will answer a bit more tomorrow. This project is initially an attempt on reverse engineering of the new Audio Note balanced products. http://www.triodeandco.us/Welcome_fi...Amps080105.pdf Sincerely I have an AN m3 transformer coupled preamp so I guess it will match well. |
#7 | |
The CineMag CMMI-3.5C should give you what you want plus a little extra. se |
#8 |
Dear friends. I got an email from sacthailand, and they told me it was not suitable in that place.
However my speakers are aprox. 108 db sensitivity, and I assume I have enough with a 1:2 step up? When using 1/2 5687 I get approx 15x gain which seems a bit low, with a step up I get 30. The reason for this setup is that I have a bunch of 5687 valves and 300b valves. Would really like to do something with them. AN stuff has always interested me. Sincerely |
| Lundhal line input transformer question... | sklimek | Parts | 9 | 11th January 2011 07:43 PM |
| Jensen JT-11P-1 Line Input Transformer | csrote | Analog Line Level | 0 | 13th December 2008 09:40 PM |
| PCB mount line input transformer question | audiowize | Tubes / Valves | 0 | 11th July 2008 07:05 PM |
| need input on SS buffer w/transformer line amp. | AudioGeek | Solid State | 0 | 17th January 2005 08:23 PM |
| line output to xlr mic input | bogusblackman | Everything Else | 7 | 28th February 2004 12:32 PM |
| Page generated in 0.10002 seconds (79.36% PHP - 20.64% MySQL) with 10 queries |
