| diyAudio Sponsor | ||
Gents,
It seems that there are many good things to be said about the Electraprint. Im looking at their 1:1 5k:5K IT for my application of a 45 to drive my 813SE. Just curious if anyone has any other suggestions before I pull the trigger.... Thanks ! Steve |
#2 |
tarmac ripper
Electraprint irons? 45? 813? Interstage coupling? All of them sound good to me. Strap the 813 as a triode. What other tubes will you use in that amp?
Ciao Gianluca |
#3 |
Hello !
I am going to use the tubelab DHT-SE board. It uses a 5842 as a driver into the 45. |
#4 |
Gents,
I ordered up a set of 5K 1:1 IT's from Electraprint...So am I going about it the proper way here ? I am also thinking about maybe going fixed bias on the 813 - but that would require yet another transformer in the PSU; so I'll have to think about that some more....If I do go that route - I have seen where the negative voltage gets fed directly into the secondary of the interstage - sound about right ? ![]() Thanks guys ! Steve |
#5 | |
#6 |
Brett,
Understood - I was under the impression that I needed quite a bit of swing though ? |
#7 | |
#8 |
I don't see how it is too much gain. 5842 yields about 35 and the 45 another 3. So we have 105x for this combo. 80 Vg is ~160Vpp, so that gives us 1.5Vpp input sensitivity of (1Vpp = 1/(2*sqrt(2))Vrms right?) 0.53Vrms input sensitivity. A bit much maybe I guess. So I guess I recant...
#9 | |
#10 |
Using an IT with the 45 I absolutely would not run it at more than 275V and would recommend something like 250V at 32mA or so which seems to be a sweetspot with most vintage 45 I have encountered. Grid bias voltage at this current and plate voltage would be about -48V.
I would probably run the 813 in triode mode, but that's just me. I'm currently working on a design using 5842/45/845 as a possibility for my next amplifier. I'll be using an IT, but the 845 requires significantly more drive than the 813 so I don't expect quite the gain issue you have, although you could treat this as an integrated amp in which case the available gain would seem suitable. I used custom made Electra-Print transformers in my headphone amplifier and am very pleased with the result.
www.kta-hifi.net |
| Interstage X-former identification | Klimon | Tubes / Valves | 0 | 14th October 2007 08:29 PM |
| Wim's hybrid interstage amp | DG | Solid State | 4 | 10th October 2007 08:49 PM |
| LTP with interstage trafo | croccodillo | Tubes / Valves | 8 | 8th June 2007 01:01 PM |
| 4K:10K interstage | astouffer | Tubes / Valves | 0 | 24th March 2005 04:34 PM |
| Interstage trans? Yes please! | Gluca | Tubes / Valves | 11 | 3rd March 2005 11:52 AM |
| Page generated in 0.10325 seconds (77.03% PHP - 22.97% MySQL) with 11 queries |
