Old 25th August 2008, 02:50 AM   #41
zcables is offline zcables  United States
It's a piece of plexiglass that has been painted black on the back side. It ended up being really reflective because of the shiny top with matte back. The hardest part was cutting the holes with a hole saw because when it heated up even a little, it would stop cutting. I ended up having to dunk the tip of the hole saw in ice water every 10 seconds or so to keep it cutting.
Old 25th August 2008, 03:07 AM   #42
gofar99 is offline gofar99  United States
Hi, Excuse me if I laugh. I've been there too. The one project (Oddwatt) amp used 3/8 inch thick high strength plexiglass. Oh fun and games. Part of the way I finally did it was to slow down the speed and drill a little on each hole then move to the next until all six were done. I now use a drill press and real slow (500 rpm) speeds to drill things like that.
Nice job finishing on you part.
Keep up the good work, have you had a chance to hear how the amp sounds? If so with what sources and speakers.
Good Listening
Bruce
Old 25th August 2008, 04:13 AM   #43
It sounds suprising good for being a lower priced kit. I am enjoying the sound except for a bit of a hum which I should be taking care of this week (and hopefully upgrading a little ).
I am using the amp for my computer rig, so it starts with my Vista PC using lossless files. Optical out to a AMC 8 DAC, plugged into an Adcom power center. My speakers are a pair of Polk Monitor 5Jrs that I upgraded with RDO silkdome tweeters and rebuilt the x-overs using Mills and Jantzen components. The speaker cables and ICs are star quads that I custom made.
Also, I was looking at rolling tubes on this amp since I just have to stock 6005s. I was eyeing either EL90 or 6AQ5, but am open to whatever. Do you know what are high quality tubes for this application since I'm sure the ones that came with the kit aren't exactly audiophile.
Old 25th August 2008, 02:25 PM   #44
Hi, I'm not up on that particular tube type. Someone out there may have some thoughts on them for you. I'll ask as well. Sounds like a pretty good set up for that amp. The hum can be tamed to reasonable levels without a great amount of work or cost. The stock hum levels in the K-12 series was bet 5 and 10 millivolts at the speaker. It can be brought down below 2-3 fairly easily. Below that requires $$ and effort.
Good Listening
Bruce
Old 1st September 2008, 11:08 PM   #45
Default Just finished my S-5 kit
Wow,
The stock K-16LS sounds fantastic. I am eager to see what it will do when tweeked. My amp is driving two 8ohm PhazeTechs very well I don't hear much hum and there is zero buzz. It may be the position of the output transformers at this time. Restoring pinball machines is my main hobby but this may take over. I have ordered the upgraded output transformers from Edcor. wonder what type of improvement the bridge mod does. I don't have any diodes of that size in house but was wondering if 4004s would work. I will take on the cap upgrades next and then design my chassis to expose the "goods". It's great to know that there is such a deep base of knowledge out here.
Thank you all for your input.
Pascal.
Old 2nd September 2008, 12:17 AM   #46
Hi, I'm glad the amp is up and running and you like the sound. I would not bother replacing the stock rectifiers with 1N4004s. No real improvement. Fast recovery rectifiers are available from several sources and are really cheap. The biggest problem is the associalted packing and shipping fees most companies charge. Which Edcors did you order? I found the best improvement in most of the tube amps I have worked with is to replace the interstage coupling capacitors. The most dramatic was in the K-12. Since then, I usually start with good caps and save the step. Power supply mods will help with the noise floor and bottom end as well.
Good Listening
Bruce
Old 3rd September 2008, 06:36 AM   #47
Default Edcor 25w 8ohms (CXPP25-8-5K)
There is a two week wait for my opt's from Edcor. They are the 25w 8 ohm "cutties" you have parked on top of your very cool Oddwatt 225. Can I go through Mouser for the Gold caps or is there another place you would recommend? I went to the Goodwill today and found my box and chassis in the form of a $2.99 brass serving platter and some scrap poplar hardwood. Pics soon. Again, I just can't get over the sound that is produced through this amp. The strings! I can hear the fingers hitting the strings as they play. Is it my imagination? or have I been listening to crap all these years? I am going back through all my music again and nothing so far sounds the same.
Thank you for the heads up on high voltage. As someone who has experience underneath a pinball playfield I do understand the dangers involved.
Take care,
Old 3rd September 2008, 03:25 PM   #48
Hi, They should be a good match and will allow for some experimentation on selecting a load tap for your speakers. Not all are as they claim. I usually get my parts, from Parts Express, MCM, Antique Electronic Supply, Digikey or Allied. Mouser is also good. Check prices and shipping for the best deals.
Your choice of chassis seems interesting. I find many such things in the kitchen section of department stores. I will be posting some new projects in a couple of weeks that use wooden (bamboo) kitchen organizers for chassis.
Good Listening
Bruce
Old 3rd September 2008, 04:29 PM   #49
Well friends, I just installed the 270K bleeders for the fun of it and the .01uF cap on the HV wires. Unfortunately, that didn't get rid of any of the buzz, so I will be upgrading the filter caps next and looking at the diodes. Also, maybe trying some snubbers across the filaments of the tubes.
At this point, I'm just having fun trouble shooting this project and using the oscilloscope to look at the buzz and oscillations.
Old 3rd September 2008, 11:40 PM   #50
Originally posted by bayermar
- I paralleled the HT cap (C10 in your schemo) with a Solen 22uF PP film. Hugh improvement in detail (Highs, but also in bass - maybe a case of placebo, since I have no switch to go back and forth). Even if Placebo, I liked this mod very much.
Would this be necessary since I am replacing all of the filter caps with higher quality and larger value caps? I know when I have rebuilt speaker xovers in the past I have omitted bypass caps because they became irrelevant with high quality caps, and just ended up sounding unnatural.
K-16ls kevin.dickerson Tubes / Valves 7 27th April 2011 01:37 AM
K-16LS Help Please Madmen Tubes / Valves 6 10th December 2008 09:26 PM
S-5 K-16LS Kit arrived in Germany !! lufton Tubes / Valves 10 19th November 2008 10:59 PM
K-16LS kit Assembled and Working 123rmp Tubes / Valves 10 14th July 2008 01:21 PM
S-5 16LS tube amp use with 8 ohm speakers 123rmp Tubes / Valves 8 13th April 2008 11:40 PM
Copyright ©1999-2013 diyAudio
