Review of New S-5 K-16LS Kit - Page 16 - diyAudio
Old 8th December 2012, 12:14 AM   #151
I just bought and built this kit as well. I built it stock with the exception of using Orange Drops for the coupling caps and putting snubbers across the filament pins of all tubes. I also twisted the filament wires from the power transformer to the baord (as directed in the instructions). This amp sounds great and there is no hum what so ever. I plan on upgrading the OPTs to the EDCOR CXPP25-8-5k and changing out the rectifier to four UF4007 diodes with cap/resistor snubbers across each one. I would also like to try a UL configuration with the new EDCOR OPT - has anyone tried this? HOw did it work?
Old 21st January 2013, 05:41 PM   #152
Thank you all for this excellent thread. I have built two amp kits already and just ordered the 16LS today. I'm going to be putting in the larger electrolytic cans (getting quality ones too), doing orange drop caps and the good mica caps. A couple of questions:
1. I am going to be running 4 ohm speakers with this. I hear the output transformers included with the kit are crap. The Edcor iron recommended in this thread is for 8 ohm output. Does anyone have a usable 4 ohm quality transformer for this application?
2. Are there any tube upgrades? Some other beam tetrode that is more powerful or better sounding?
Thanks for your help.
Also - I've been looking at the Edcor CXPP30-MS-5K as a replacement to run 4 ohm speakers, would this work?
Old 23rd January 2013, 02:02 AM   #153
The Edcor CXPP30-MS-5K should work fine. On my K16 I upgraded the coupling caps to Orange Drops and the PS caps to JJ caps. I am not sure the ODs helped any but the amp is very quiet with no noise or hum so i am very happy with the power supply. I do not know of any upgrade to the power stage tubes but these in the kit are fine at normal listening volumes. Turn it up however and you will hear the distortion - past 12:00 is not good. Overall it was a good kit to start with but left me looking for more. So now I am in the process of building the Podwatt 2C DIY now. A bit less power in theory but I think it will sound much better when done.
My speakers are Nuance Series 5 units with 89 dB/w sensitivity and the listening area is not large ~120 sq ft.
Old 19th September 2014, 05:58 AM   #154
joshrd is offline joshrd  Canada
Hi everyone,
I know I'm resurrecting an old thread, but my friend is having issues with his K-16LS amplifier. There is a constant buzz on the left channel -- even if there is no input -- and a slight buzz on the right channel.
I'm fairly familiar with electronics, although my tubes knowledge needs brushing up.
There seems to be a steady buzz out of the left channel. I suspected it was a faulty output transformer, but after swapping it with the right channel, the buzz persisted. However, touching the transformer chassis reduced the buzz.
The next thing I checked was the common grounds, and everything seemed to check out fine. (I didn't do an extensive check, due to time).
Finally, I'd arrived at the input transformer, which is where I'm at now. Is it possible that one of the HV caps (c10, c11) is kaput and is causing the buzz? I haven't tried removing/replacing it yet? I am also hoping to add VoltSecond's mod before the rectifier circuit.
Any help/reading material would be useful and appreciated.
Old 20th September 2014, 12:01 AM   #155
What is the size of the PCB ?
And what size enclosure / wood frame are you using ?
What's size frame / enclosure if you are using their tone control or pre-amp ?
Thanks, Kevin
Old 20th September 2014, 12:03 AM   #156
What size enclosure or wood frame is everyone using ?
What size if using the preamp or tone control ?
K-16ls kevin.dickerson Tubes / Valves 7 27th April 2011 02:37 AM
K-16LS Help Please Madmen Tubes / Valves 6 10th December 2008 10:26 PM
S-5 K-16LS Kit arrived in Germany !! lufton Tubes / Valves 10 19th November 2008 11:59 PM
K-16LS kit Assembled and Working 123rmp Tubes / Valves 10 14th July 2008 02:21 PM
S-5 16LS tube amp use with 8 ohm speakers 123rmp Tubes / Valves 8 14th April 2008 12:40 AM
Copyright 1999-2017 diyAudio
