Review of New S-5 K-16LS Kit - Page 15 - diyAudio
Old 7th August 2012, 05:58 PM   #141
andrejg is offline andrejg  Slovenia
Originally Posted by TheGimp View Post
andrejg,
If you are using SS rectification you might try a snubber (10nF cap in series with a 10R resistor) across each diode.
The resistor value may need to be adjusted up to achieve best suppression of switching noise.
thanks, i'll look into that. though since i replaced the stock rectifier with four uf4007 diodes and the capacitors with larger ones the hiss is audible only when you're closer than, say, 10cm from the speaker (at a normal listening volume). it is very much audible when the volume is increased to about 50%, but then the music is much too loud to be enjoyable.
Old 7th August 2012, 07:41 PM   #142
TheGimp is offline TheGimp  United States
TheGimp's Avatar
The larger caps actually make it worse as the current pulses are greater and occur over less of the ac cycle.
While the snubbers don't help UF4007s as much as they do 1N4007s, they still may help.
Old 8th August 2012, 12:13 AM   #143
oldschooltube's Avatar
Default Tube Rectifier
Here's what I did for tube rectification on my 16ls amp. The rectifier tubes are 6BY5GA television damper diodes. If you choose to go this route with your kit you must replace the first capacitor in your amp with a lower value as the TV damper tubes cannot handle anything over about 50 uF. I paralleled 2 of these tubes for half of a hybrid bridge and used ss diodes for the negative half. This hybrid setup did not drop the voltage too much so the stock power transformer can stay in service. The result is less switching noise and a nice slow ramp up of the B+ instead of blasting cold tubes with the full voltage before they can warm up.
Overall I love the tubes in the back because they look cool and make for great sound.
Just remember, check everything twice. Then check it again because you can't put the smoke back in after it comes out!
Old 8th August 2012, 01:01 AM   #144
I forgot to mention you will need to add a separate filament transformer if you keep the stock power transformer in service because the 6by5 tube needs 1.6 amps of filament current.
Old 10th August 2012, 07:46 AM   #145
Default caps and tube rectifier
Hi all
QUOTE:
Bigger filter caps (220 uF, 220 uF, 100 uF instead of 220, 100, 22)
so basicly all 100 are replaced with 220 and all 22 with 100?
For the tube rectifier; it doesnt do anything for your sound - it's only for at slow start of the amp tubes?
br. d.loncar
Old 10th October 2012, 04:36 PM   #146
UJF is offline UJF  United States
Default S5 16LS Amp Kit
Hello,
I am planning building a S5 Electronics 16LS amplifier. I see it has no Output for headphones. I presently have AKG 600 ohm phones.
Can anyone recommend a headphone amp kit I can add to the 16LS package, perferrably tube type?
Thank you everyone.
Old 24th October 2012, 06:30 PM   #147
UJF: I use the Bottlehead Crack. It would pair nicely with your high impedance phones.
Old 24th October 2012, 07:46 PM   #148
Thank you andfejg, for the reply. I have been in contact with Larry at S5 and he recommended I could tap directly in the 16LS " A 220 ohm resistor in series with each speaker out (read wire) to corresponding headset speaker and the common to ground (one of the black wires). You could do this externally or internally to a jack for the head phones. "
How do you (or any other owner) like your 16LS and did you make any changes or additions to improve your perception of the sound quality?
Again thanks.
Old 25th October 2012, 08:54 AM   #149
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
is this a similar design ?
tho it does not come with trafos, I wonder if it would be a good EU-alternative
http://electronics.dantimax.dk/Kits/...mps/index.html
Old 4th November 2012, 01:57 PM   #150
Dantimax (elektronik) - Tube_pre-_-_poweramps
i've had my eye on their kits for a long time, especially the tube preamps. if you look carefully they have the appropriate transformers for their kits (and a bunch of other stuff) listed in the parts and accessories section. if i had found their site before i found about the k-16ls i would have probably bought their kit. even if just to avoid import taxes and duties (and taxes on shipping costs and taxes on taxes ).
perhaps one day, when money's not so tight .
(is it just me or does the thread subscription work in a weird way? i've set it to instant notification, but most of the time i don't receive any notifications?)
K-16ls kevin.dickerson Tubes / Valves 7 27th April 2011 02:37 AM
K-16LS Help Please Madmen Tubes / Valves 6 10th December 2008 10:26 PM
S-5 K-16LS Kit arrived in Germany !! lufton Tubes / Valves 10 19th November 2008 11:59 PM
K-16LS kit Assembled and Working 123rmp Tubes / Valves 10 14th July 2008 02:21 PM
S-5 16LS tube amp use with 8 ohm speakers 123rmp Tubes / Valves 8 14th April 2008 12:40 AM
Copyright 1999-2017 diyAudio
