Review of New S-5 K-16LS Kit - Page 13 - diyAudio
Old 3rd April 2009, 09:07 AM   #121
gljiva is offline gljiva  Croatia
Another one...
Old 13th April 2009, 03:05 PM   #122
Angry 16LS Stereo Integrated Tube Amplifier
hi there people can some one help me i have been out bit on to amps now on eBay a music fidelity A-100 and a Cyprus one amp. i am thinking of buying a 16LS Stereo Integrated Tube Amplifier kit but want do they sound like.do they sound as good as the other amps i have listed or should i just buy a sound hand one from eBay and keep bidding. i have soldering skills and a bit of electronics behind me.at the moment i have a set of mission speakers mv6 and a old Yamaha AX-300 and a Cambridge audio CD5 player.want do you people think get a better CD player and keep my amp or get a better amp.thanks everyone
Old 25th April 2010, 04:29 PM   #123
Default Troubleshoot 16LS Amp Kit
Hello I need some help from tube world gurus on troubleshooting 16LS kit.
I am new to tube amps sorry for basic questions. I read lots of posts on 16LS,mostly reviews and some upgrades but did not see many posts on how to fix some common problems with Tube amp. My 16LS kit is mounted in aluminum case and some upgrades, RCA and speaker plug and vol control because kit one was scratchy.
I built a 16ls kit and set of speakers 4ohm and have notice 2 problems:
1. a slight noise like some radio or humming can hear it only near L/R speakers both make same noise.
I think this may be some ground problem or loose contact.
2. Initially amp sound good but after 5-10 min of music left speaker start popping and sound level goes down like popping scratching noise only on one side. Right channel works fine no such distortions. After popping stop it play normal but left side sound is notably reduced.
This kit is new and I do not suspect any old parts or tubes so do not know what the problem can be or how to fix it. My initial suspect is faulti capacitors some delay discharge or power supply problem, but why only one side?
Help troubleshooting and advice on parts is appreciated.
Old 31st May 2010, 11:46 PM   #124
Default Speakers
I am thinking about buying one of these tube amp kits. Could I used my bose 8 ohm speakers with it? thanks for you answers.
Old 10th September 2010, 08:07 AM   #125
ryanj is offline ryanj  Australia
yes you could use 8 ohm speakers
Old 25th February 2011, 10:21 PM   #126
tony Ma is offline tony Ma  United States
Originally Posted by stl View Post
Here is the design I am shooting for and the progress so far (K16LS).
Mods completed:
- 220uF (450V), 220uF (250V), 100uF (250V) capacitors
- 6 Sonicap .22 uF (400V)
- 2 Silver Mica 33pF
Using lead free Cardas Tri Eutectic solder.
Can you pls refer me where to buy those?
Old 11th March 2011, 02:12 PM   #127
Hi folks, how are you?
I'm planning to adapt the tone control K-TL to my K-502 amplifier, so i ask if it will work properly. Anyone have tried this?
And i would like to ask if anyone have the schematic of the tone control, so i could purchase the components and assemble it by myself.
Many thanks!
obs. sorry for my poor english, 'im brazilian!
Old 12th March 2011, 02:30 PM   #128
I just finished one too, see pic and other thread for more info.
Old 11th April 2011, 01:40 AM   #129
Originally Posted by zcables View Post
Here is my K-16LS. The wiring is a little crazy since this was my first amp build, but everything work well and I'll be even better once I get a few of those mods on it.
What type of transformers are those?
I'm hitting "purchase" on the S-5 website right now...
Old 5th July 2011, 11:23 AM   #130
Hi
New at forum. What a great source of information. Anyway: just built a 16ls tube AMP from tubedepot.com. Along with that a tube RIAA and a input selector.
My question is, Can i use common Ground for these three components.? Im having a bit of hum and hf noise. But at This point All the components are exposed and whitout a chassis. Before i begin to do some mods i'll try with the grounding and chassis.
Thanx a lot in advance.
Best regards
D.Loncar
K-16ls kevin.dickerson Tubes / Valves 7 27th April 2011 02:37 AM
K-16LS Help Please Madmen Tubes / Valves 6 10th December 2008 10:26 PM
S-5 K-16LS Kit arrived in Germany !! lufton Tubes / Valves 10 19th November 2008 11:59 PM
K-16LS kit Assembled and Working 123rmp Tubes / Valves 10 14th July 2008 02:21 PM
S-5 16LS tube amp use with 8 ohm speakers 123rmp Tubes / Valves 8 14th April 2008 12:40 AM
Copyright 1999-2017 diyAudio
