Review of New S-5 K-16LS Kit
Old 11th March 2009, 03:14 PM   #111
gljiva is offline gljiva  Croatia
Back view
Old 11th March 2009, 03:14 PM   #112
Top
Old 11th March 2009, 09:00 PM   #113
This is a first time that I build a tube amp.
Did not all by myself, had a big help of my 12 year old son.
He did all soldering exempt connecting the transformers, and I was mostly busy with mechanical part.
First time connected to the mains and everything was working fine. A bit of hum and noise but 70% off sorted with proper grounding. No smoke no bang...
Sound is very clear but not really warm. Missing bass, and mid range sounds to strong.
A bit disappointed to be honest. So now, need action to be taken to try to rectifier that.
I was thinking to do something of that:
1. to order tone control unit
2. to try with equalizer
3. maybe new output transformers
4. or to build new tone control unit, but that means new power supply as well (all with tubes off course).
Any advice or comment would be greatly appreciated.
Old 12th March 2009, 02:02 AM   #114
stl is offline stl  United States
You might have already seen this, but if not, below are links to modifications made to coax better sound out of the S5 kits. The links are referring to the K12M kit, but most most mods could be applied to the K16LS kit with similar results, if properly executed.
Links:
VoltSecond
Bruce
Giovanni
Old 13th March 2009, 09:26 PM   #115
Thanks stl
Old 18th March 2009, 03:59 AM   #116
gmilitano is offline gmilitano  Canada
gmilitano's Avatar
gljiva, I have had emails from others who are not pleased with the K-16LS. It seems to have the same problems as the K-8LS. Here is another person unhappy with the k-16ls tube amp
Let us know how you make out.
Old 18th March 2009, 10:05 PM   #117
Thanks for link gmilitano.
I don't have to much of spare time lately to play with.
Anyway, if happen something I will let you now.
Cheers.
Old 25th March 2009, 10:25 AM   #118
Good Day,
Take some time today and connected laptop to k16.
Huge noise to sorted first by disconnecting laptop from mains. After that almost complete silence.
So back to business. Used winamp with equalizer preset on techno.
Must tell you result was perfect. Clear and soft sound. So far best results without messing around with tools.
Speakers I using are mission 773. See pictures:
Old 25th March 2009, 10:27 AM   #119
One question, by the way. It is possible to attach more than one picture at a time or...?
Old 3rd April 2009, 09:05 AM   #120
Still working on it. Never ending...
Review of New S-5 K-16LS KitHide this!Advertise here!
K-16ls kevin.dickerson Tubes / Valves 7 27th April 2011 02:37 AM
K-16LS Help Please Madmen Tubes / Valves 6 10th December 2008 10:26 PM
S-5 K-16LS Kit arrived in Germany !! lufton Tubes / Valves 10 19th November 2008 11:59 PM
K-16LS kit Assembled and Working 123rmp Tubes / Valves 10 14th July 2008 02:21 PM
S-5 16LS tube amp use with 8 ohm speakers 123rmp Tubes / Valves 8 14th April 2008 12:40 AM
Copyright ©1999-2017 diyAudio
