Plus biasing heater (220vdc above ground)
Old 24th February 2003, 12:51 PM   #1
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Plus biasing heater (220vdc above ground)
My question is am I doing long term damage to the tube?
Ie does the heater cathode insulation spec also pertain to negative difference.
Usually the heater cathode insulation pertains to the potential of the cathode ABOVE heater..but now it is BELOW......... but by a margin that is above heater cathode insulation spec.
A little sidenote is...that is sounds very very good this way...
Old 24th February 2003, 01:00 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default HEATER TO CATHODE INSULATION.
+ or - doesn't matter,you should measure between heater and cathode.
Not with respect to ground.
Frank
Old 24th February 2003, 01:04 PM   #3
Thanks Frank..
Thought so...what is the damage being done actually?
Chees,
Bas
Old 24th February 2003, 01:08 PM   #4
fdegrove's Avatar
Default HEATERS.
At first you'll hear the valve go into HF oscillation, some report LF oscillation but I never heard of that.
In the long run the heater and cathode will "stick" creating a short.
Frank
Old 24th February 2003, 01:52 PM   #5
Default Heater / Cathode insulation
I just supposed that I am over the specs...but a look at the 6n1p datasheet does not reveal the max rating..
Anyone know?
Old 24th February 2003, 01:57 PM   #6
fdegrove's Avatar
Default HEATER.
6N1P 100V
6N1PVI 120V
6N1P-EV 120V
Frank
Old 24th February 2003, 02:03 PM   #7
You're fast Frank!
Thanks..
While I've got your attention...I've been thinking about a 6EW7 spud amp...but can get the 6DE7 cheap..and it looks very similar...Do you thing it is a good alternative to the 6EW7
Bas
Old 24th February 2003, 02:32 PM   #8
fdegrove's Avatar
Default SPUD.
The 6DE7 powertriode triode section has a max.dissipation of 7W
whereas the 6EW7 can disspitate 10W.
Other than that...up to you.
Frank
Plus biasing heater (220vdc above ground)Hide this!Advertise here!
triode heater ground question gary h Tubes / Valves 2 8th August 2009 06:26 AM
Question about biasing heater above cathode in a direct coupled circuit. G Tubes / Valves 1 26th May 2007 11:42 AM
referencing heater supply ground to B+ jarthel Tubes / Valves 2 14th March 2007 07:39 PM
Biasing heater supply above ground. G Tubes / Valves 16 3rd December 2002 03:46 PM
