| diyAudio Sponsor | ||
Hi all. I have designed a small amplifier for use in my small listening room. I am posting it looking for opinions and suggestions. I realize that some of you will not agree with the tubes that I have chosen and that is OK with me. I think it will work and sound fine but I wanted to make sure that it is as polished as it can get in spite of the crappy tubes I chose.
Gavin |
#2 |
470k gridleak is kinda high, and a .68µF / 470k is almost going to let DC through, hehe... (rolloff is like 0.5Hz... go to 100k or something.)
That and I hate direct coupled stuff, I'd cap couple it and put in a divider to bias the CF... or drop it altogether, an AU7 shouldn't have a problem driving a 12B4, I wouldn't think... but whatever. You could parallel the AU7 and have plenty of drive, if you want to use the whole tube. or if it's stereo, use 1/2 a channel.. or something like that. have fun |
#3 | |
The reason for the CF is to drive a subwoofer amp in parallel with the output stage. Also I would think that a .68uF cap into a appoximately 50K load(when driving two loads in parallel) would be a big enough coupling/output cap. I can make the cap as big as needed. I left the 470K grid leak in to keep the input impedance of the total load I will be driving as high as possible.
Gavin |
#4 |
RIP
...kinda looks like the original Bottlehead Foreplay circuit driving the 12b4, which benefited from ccs(source) loading of the VA section, and ccs(sink) on the CF.
If I were building a little 12b4 amp, I would be tempted to go push-pull. |
#5 |
Looks pretty sensible to me. Build it and see how it works!
Pete |
#6 | |
Gavin |
#7 | |
Gavin |
#8 |
Not as long as the sub amp is well-behaved. I'd be a little worried that it might inject some DC back into the grid of the 12B4.
A safer bet would be to use two coupling caps - maybe a 0.1 or 0.22 to the 12B4, and a seperate .68uF or 1uF to the sub amp. You could even try taking the 12B4 cap to the plate of the first 12AU7 (bypassing the CF) - I don't think it would have too much trouble driving the 12B4 directly. I didn't calculate what gain you'll wind up with, but I expect it will be a little low. Might be fine for your system. If you need more gain you could swap in a 12AT7 or something else (5687/7119 come to mind). Pete |
#9 | |
This is the point where my ignorance starts to really embarrass me. THe datasheet for the 12AU7A shows a "amplification factor" of 20. Will I get a voltage gain of 20 out of this circuit? If not then you are correct in that I will have to choose another tube. I would like to get as close as I can to swinging 48v PP into the 12B4A without driving it into clipping. I bought four "Vitamin Q" .68uF caps for this project so I can use one to the sub amp and one to the output stage without a problem. I can also resize the grid leak resistor on the 12B4A to something a little smaller if you feel that it is needed with the .68uF cap but I would like to use the caps I bought.
Gavin |
#10 |
Here is a updated schematic....................................
Gavin |
| New System... Please offer your thoughts/comments/concerns/suggestions! | BintheD | Car Audio | 7 | 25th September 2008 10:21 PM |
| Network Suggestions Needed: +6 dB @ 84 Hz | kelticwizard | Everything Else | 7 | 5th April 2007 05:23 PM |
| your suggestions needed | saltyreefguy | Car Audio | 4 | 24th June 2006 06:23 PM |
| Amp suggestions needed | 1108 | Tubes / Valves | 6 | 26th July 2005 08:15 PM |
| suggestions needed for HT | googleguy | Multi-Way | 0 | 26th November 2003 08:03 AM |
| Page generated in 0.12088 seconds (79.79% PHP - 20.21% MySQL) with 11 queries |
