| diyAudio Sponsor | ||
I know this isn't a tube amp question, but I didn't know where else to put this post. I've given up on passive crossovers. Having to use massive inductors and caps to obtain low crossover points is no fun. Active tube crossovers are the way to go. Being a bit of a newbie on the subject, I've been checking out Tube Cad and and Steve Bench's website to come up with a decent design. Both sections are L-R. The low pass is 4th order and thev high-pass is 2nd order. (see schematic).
My question is; what would be the best way to include a master volume for both sections that will not weigh down the high impedance at the input, or change the crossover frequency by adding extra resistance to the first section of the low-pass filter. Thank you, John. |
#2 |
Simplest voulf be to add a buffer after the VC as drawn.
#3 |
How about this one? I wasn't sure if it was totally necessary to include a coupling cap at the wiper of the pot.
#4 |
Better. I'd up the value of R11 though, and adjust cct accordingly. May find other things later as I took a short glance.
#5 |
Thank you for pointing that out Brett. Here's revision C.
| FS: MARCHAND ACTIVE TUBE CROSSOVER XM-126 3-WAY (Make offer) | Strativari | Swap Meet | 2 | 29th January 2009 04:20 PM |
| How to set volume in 3-way active crossover? | Shahriar | Multi-Way | 1 | 26th April 2008 07:31 PM |
| dbx & preamp master volume | Al.M | Multi-Way | 0 | 4th January 2007 02:33 PM |
| Tube active low pass crossover | Diy martin | Full Range | 2 | 2nd November 2006 04:48 PM |
| Low pass active tube crossover | Diy martin | Tubes / Valves | 2 | 1st November 2006 03:30 AM |
| Page generated in 0.07746 seconds (70.14% PHP - 29.86% MySQL) with 11 queries |
