diyAudio Sponsor
Old 11th January 2008, 11:56 PM   #1
Send a message via AIM to ThSpeakerDude88
Default 6AL5 for clipping diodes?
Couldn't find much on the net about this, but could a 6AL5 be used in place of the two diodes in a distortion pedal, such as a TS or any "insert popular distortion box here" circuit? Might have different clipping charactoristics if so.. and wouldn't requier a HV source for operation, only fils. Its also available from EH now apparently, for what reason I am unsure...
always preach the gospel-
and when necessary use words.
Old 12th January 2008, 12:19 AM   #2
Miles Prower's Avatar
Default Re: 6AL5 for clipping diodes?
Sure you can. The 6AL5 was designed as a high frequency, small signal dual diode (useful for making SB and DB passive ring mixers). No reason they won't work at AF. They will, however, require a volt or two of reverse bias. Silicon diodes don't turn on until the Vf rises to 0.7V. This gives you the clipping/limiting action.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 12th January 2008, 02:35 AM   #3
hey thanks! I was a little worried about that... I thought that it might just plain act like a short and pull down the signal without some sort of reverse bias... can I just put a resistor in the cathodes , or will that only act like a more resistive short?
Old 12th January 2008, 06:17 AM   #4
Your best bet would be a LED in series with each cathode for reverse bias. The AC impedance is quite low, and will hold off conduction better than a resistor. A voltage divider that puts a couple of volts on the cathodes might give a softer break. Depends on what kind of effect you're after here.
www.dolphin-hsl.com
Old 13th October 2009, 01:34 PM   #5
jim is offline jim  Belgium
If I'd build a tube-distortion-box with a 6AL5, where do I put the 6AL5 ?
In a feedback loop (like in opamp-stompboxes) or at the output of a gain-stage, wired in anti-parallel to ground ?
Thanks,
Jim
Old 13th October 2009, 04:39 PM   #6
kevinkr's Avatar
Thanks,
Jim
You can actually do either, in the case of an output there should be a resistor between the clipper diodes and the op-amp..
You can also experiment with varying levels of reverse bias on the tube. Silver Oxide or alkaline watch batteries can be used in the cathode circuits to provide reverse bias in addition to the leds mentioned previously. More complex bias circuits would allow you to vary the point at which the 6AL5 starts to conduct. Leds can also make good clippers..
www.kta-hifi.net
Old 13th October 2009, 05:32 PM   #7
How can this be done ? The bias circuit should have a high output impedance in order not to load the circuit, right ?
Old 21st October 2010, 05:24 AM   #8
1. So would a watch battery have to be in series with each 6AL5 diode?
2. Would there be an advantage preceding the 6AL5 reverse parallel circuit with a cathode follower?
3. Has anyone out there made this work?
(Merlin has mentioned reducing filament voltage to change forward conduction point).
Old 22nd October 2010, 05:22 AM   #9
Soooo.... Nobody has actually made this work?
Old 26th October 2010, 01:02 PM   #10
I tried it a few week ago, but without the reverse bias and it did not work very well. Put some led's in series with the cathodes but that didn't work either.
The 6AL5 was driven by an opamp, supply voltage 20V.
Will try this again later after I figured ou how to use the 6as6 as a distortion tube à la Culture Vulture.
Clipping richie00boy Class D 2 16th January 2008 05:36 AM
14gt8...clipping diodes? ThSpeakerDude88 Tubes / Valves 2 19th May 2006 05:39 AM
Clipping GC? drfrink24 Chip Amps 29 1st April 2005 10:14 PM
What is clipping? guitargully Solid State 5 25th February 2004 08:24 PM
Help with +VE clipping matth Solid State 7 21st June 2003 07:03 AM
Page generated in 0.10816 seconds (79.44% PHP - 20.56% MySQL) with 11 queries
