| diyAudio Sponsor | ||
Anyone ever try a 4-65A in triode? 65 watts Pd and 10 for G2 could give a 75 W dissipation for 15 or 20 watts SE. 600 volts allowable on G2. Always looking for the poor man's 300B.
#2 |
http://www.curtcass.com/OTS/2003VSAC.html#vsac
Take a look at the 4th picture. I emailed the Oregon Triode Society asking if they could put me in contact with the builder. Sadly they never got back to me. Maybe you will have better luck. The 4-65a is useless in tetrode mode so I always wondered about it triode strapped or even screen driven |
#3 |
Thanks for the lead. I'll try it and if I get some info I'll pass it along. Found a Mu of 5 g1 - g2 so that is in the ballpark. Might have to get one and light it up.
#4 | |
cheers 316A |
#5 |
I have a bunch of 4-125A`s, sockets and associated parts pulled from some 500 watt transmitters (FRT-501). A bank of four in parallel ended up a PWM modulator to kick a magnetron for a radar astronomy telescope. These are an attractive radiation cooled tube. When the plates are glowing orange (permitted) they look very serious.
The 4-125 is similar to the 4-65A. just twice the Pd. I have given some thought to a SE amp using this tube, so will follow this thread with interest.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#6 | |
cheers 316a |
#7 |
I had thought of using a 4E27A/5-125B but after hearing of your hum problems it might be harder than I thought. Someone posted triode curves of this tube showing an Rp of 1200. Perhaps using a HF switching supply would help?
#8 | |
cheers 316a |
#9 | |
You are probably right that the 4-125A represens a challenge to fit into a practical audio amplifier. Of course this challenge, the journey as it were and the resulting esthetic beauty of transmitting bottles in your Hi-Fi setup are rewards some of us enjoy. I have a pair of 450-TH`s here that just beg to be used in a monoblock subwoofer amp project!
#10 |
Thanks to all for the help! You saved me many hours and much greif. I may still try one of these tubes but you have shortened my learning curve quite a bit.
| Triode curves for 6AU5 | boergars | Tubes / Valves | 8 | 24th April 2012 09:59 PM |
| 7788 Triode Curves | dsavitsk | Tubes / Valves | 89 | 21st July 2011 09:27 PM |
| 814 triode curves | ailouros6 | Tubes / Valves | 9 | 29th April 2009 05:04 PM |
| Derive Triode Curves from Pentode Curves? | dsavitsk | Tubes / Valves | 3 | 14th May 2007 06:10 PM |
| 6AK5 Triode Curves | dsavitsk | Tubes / Valves | 2 | 29th March 2007 06:20 PM |
| Page generated in 0.12962 seconds (82.79% PHP - 17.21% MySQL) with 11 queries |
