diyAudio Sponsor
Old 3rd January 2008, 04:20 PM   #1
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default Simple Magic Eye Circuit Wanted
Hi.
I have several magic eyes but I like the look of the EM71.
Does anyone have a simple circuit to drive and power on of these??
Andy
Old 3rd January 2008, 04:48 PM   #2
http://www.akh.se/tubes/htm/em71.htm
Old 3rd January 2008, 05:00 PM   #3
I have a little magnavox amp with an unused tube socket that i'd like to do something similar with. I have a bunch of NOS EM84's laying unused.
Born in the wrong decade.
Old 3rd January 2008, 05:08 PM   #4
poynton's Avatar
Hi
Thanks - that will probably do the job !
What resistor / drive arrangement will be required on the input ?
I assume a capacitor will be required so it's AC not DC ?
Andy
Old 3rd January 2008, 06:17 PM   #5
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
If using it as a level indicator to detect a signal that contains no DC. You will have to rectify the signal to produce a negative voltage. Then use a cap to filter it to -DC. So a diode and a cap or a bridge rectifier and a cap. And you will probably want to put a bleeder across the cap so it doesn't just hold the lowest value for ever.
If detecting a signal that also contains a positive DC. You must first use a coupling cap to block the positive DC before doing the process mentioned above.
If your using it to detect bias I'll have to see the circuit your adapting it to.
Old 3rd January 2008, 07:11 PM   #6
poynton's Avatar
I just want to put a level indicator on the front of an amp.
Andy
Old 3rd January 2008, 08:17 PM   #7
Jeb-D.'s Avatar
From that spec sheet it looks like the range is 0-20V. So you will have to tap it off a pretty strong signal. And you may have to make a voltage divider to give you good range on the display.
Old 3rd January 2008, 08:29 PM   #8
Tubes4e4's Avatar
The attached circuit is an excerpt from one of my projects. EM71 has an interesting non-linear, degressive characteristic somewhat suitable for output level (power) "metering", showing movements at low levels already, while not running into full reading too fast.
Tom
P.S.: The C3 value as shown is vast overkill; depending on B+ quality this cap even can be left out altogether.
If in doubt, just measure.
Wanted: Simple soft start circuit MtBiker Solid State 14 4th August 2010 08:27 PM
Looking for a simple circuit Skitch72 Tubes / Valves 19 12th August 2009 07:31 PM
HELP-- I need a simple 50W AMP circuit --- MTO audio Solid State 5 9th August 2007 06:46 AM
Page generated in 0.09754 seconds (78.43% PHP - 21.57% MySQL) with 11 queries
