Old 21st February 2003, 10:30 PM   #1
G is offline G  United States
G's Avatar
Default Current limit of EL84 grid?
Hi All,
What would be considered too much current on the grid of a 6BQ5?
G
Gavin
Old 21st February 2003, 10:41 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Default GRID CURRENT.
On wich one?
Frank
Old 21st February 2003, 10:44 PM   #3
G's Avatar
The signal grid.
G
Gavin
Old 21st February 2003, 10:49 PM   #4
fdegrove's Avatar
Default 6BQ5
So what is your concern ?
G1, the control grid is hardly taking any current at all in normal operation.
Look at a datasheet and it will give you typical operation points.
Frank
Old 21st February 2003, 10:52 PM   #5
G's Avatar
I guess my concern is what the result will be on the EL84 if I run my 5687 in the gain stage at 18 - 20mA other than sounding better. I didn't think it would be a problem. I looked at the data sheet and could find nothing about maximum current on the signal grid. Only a spec for the shield. Thanks Frank.
G
Gavin
Old 21st February 2003, 11:03 PM   #6
fdegrove's Avatar
Default 6BQ5
Gavin,naturally you wont find anything on the control grids maximum dissipation (Watts,current) since it won't be taking any of significance.
I think your concern is one of : will I send my powertube into clipping with the 5687?
To which my answer is: normally not unless you send the 5687 into clipping already.
Look at the function of the grid as if it was the flowcontrol element of a mechanical valve and you may understand its' function better.
Frank
Old 22nd February 2003, 02:10 AM   #7
Joel is offline Joel  United States
Joel's Avatar
Gavin,
Your question really is: does the current of the driver flow 'through' the grid of the next stage? to which the answer is "no".
The current of a voltage amplifier flows within its own plate circuit - without the current, there would be no rise and fall of voltage across the plate resistance (the "load"), and hence no amplification. The current is DC. In an RC coupled stage the coupling capacitor blocks DC - so the "grid circuit" is an open one.
(there is some current demanded by the input capacitance, and to disacharge and charge the coupling cap - but it's very small, and that's another topic.)
So, basically you can drive the most fragile tube with 100mA of driver current if you like. No damage will occur.
Old 22nd February 2003, 04:04 AM   #8
G's Avatar
Thanks Frank and Joel. I feel better now.
G
Gavin
Old 22nd February 2003, 04:07 AM   #9
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
The control grid will not draw any current (well, some, but very very small amounts) when it is negatively biased.
now if G1 was positive in comparison to the cathode, then you'd pull some current worth mentioning.. (positive grid is denoted by a subscript '2' after the class, for A, AB, and B. I dont know about class C for sure.. but class C is a RF thing anyways..)
certain tubes need to be positivley biased if you want to get anything out of them, its just the nature of their curves.. (811 comes to mind)
Old 22nd February 2003, 04:16 PM   #10
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Actually class C isn't an RF thing... if you want an efficient PA system, class C PP is the way to go. And there's plenty of class A and B RF stages. It's just that you can get much better (performance, efficiency, etc.) out of class C.
Tim
How to make current limit for PC supply? luka Power Supplies 10 27th February 2007 03:31 PM
EL84 grid voltage? Davy Tubes / Valves 13 15th September 2006 12:22 AM
ALW Regulator Current Limit? fmak Solid State 7 27th January 2006 08:38 AM
Which NTC to limit inrush current Mlaen Solid State 24 10th February 2005 12:52 AM
LED current limit resistor value calculator tomchaoda Parts 0 21st September 2004 04:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
