| diyAudio Sponsor | ||
I just finished my s-5 k-16LS kit and plugged it in for my first ever tube experience. There was a loud pop and a bright light and that's it. I'm hoping someone can help me figure out what went wrong.
The resistor that blew up was a bleeder resistor on the first power cap. I installed 270K resistors across the leads of each electrolytic cap according to the safety page on bottlehead. The power rating was 1W. I also upped the capacitance of the second and third power caps, but not the first (on which the bleeder blew). The capacitor still looks as though nothing bad happened to it. Another thing I was suspicious about is a cooling fan that is connected to wall power before the primary. Its specs are 115VAC, 130mA, 10W max. The 1 1/2 amp fuse before the PT primary is still fine. I would just remove the bleeders and give it another shot, but I really don't want to blow up a cap or do any more damage. Any advice? |
#2 |
Can you post a schemo of the power supply? It takes over 500Vdc to poof a 270K / 1W resistor. Are you sure it didn't just flash-over? That's a lot of voltage across one resistor.
Definitely don't remove the bleeders, and don't try again until this problem is sorted out. |
#3 |
Is there any chance that the resistor that failed could have accidentally been something other than 270k ohms, perhaps 27K? I've done that before when the colour bands on different resistances were too similar to differentiate without actually measuring the resistance.
Just a thought from my own experience. |
#4 | |
Double check the values are right and that everything is stuffed in the right place. Also, make sure the caps are connected in proper polarity. Trace the traces to verify so. The S-5 kit I bought (was a k-502) had the silk screen backwards which caused me to blow the power supply caps. |
#5 |
Here is the schematic. The resistors are indeed 270K 1W. C7 on the PCB is located right in line with C10 and C11, so I took it to be one of the power caps as well -- I put bleeders on all the electrolytics. The capacitors were in the correct polarity as well.
#6 |
Sorry that image is such poor quality. I had to reduce my scan way down for the site to let me post it.
#7 |
Run it without the one that blew. All the caps will still discharge without it as long as you leave the other bleeders. It just may take a little more time to discharge the one without.
#8 |
I agree with Jeb. You already have a bleeder on the next cap and it will take care of discharging all of the capacitors. If the amp appears to work fine otherwise, run it that way.
#9 |
Now it's R26 (between the two 220uf electrolytics) and the bleeder on c11 that are going out. They are just getting dark and smoking as opposed to flaming instantly.
#10 |
- Those caps that you increased in value, is the voltage rating at least the same as the originals?
-Make sure those electrolytics aren't in backwards. -Try leaving the C7 bleeder only. -What is the voltage rating on C7? That should give an idea of operating voltage for the circuit. Make sure the Max working voltage of the resistors your using for the bleeder are at least that value. -After the brief power up with C7 bleeder only. Quickly feel the insulated part of the caps to see if their heating up. Only use one hand and be careful not to touch anything else, as the circuit may not be completely discharged by this time. -Remember not to apply a signal without a load attached. |
| Which resistor type for emitter resistor? | sajti | Parts | 25 | 8th April 2009 06:12 AM |
| Possible blown amp | derrickg | Car Audio | 0 | 11th April 2007 09:02 PM |
| blown sub | wharfrat | Subwoofers | 10 | 23rd May 2004 05:12 PM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| ETI-480 sub amp blown :-( | Circlotron | Solid State | 32 | 21st May 2003 03:54 PM |
| Page generated in 0.09736 seconds (80.99% PHP - 19.01% MySQL) with 11 queries |
