MOSFET follower driver oscillation
Old 18th January 2008, 08:37 PM   #11
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
hi sheldon, could it be you got your zener diode backwards? i would use them back to back...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 18th January 2008, 08:46 PM   #12
Sheldon is offline Sheldon  United States
Originally posted by Wavebourn
Ground loop may be?
I'll look closely, but I have no problem when the source is loaded with a 10K resistor instead of the CCS.
The DN2540 is a depletion mode device. The gate is at lower potential than the source.
Sheldon
Old 18th January 2008, 09:01 PM   #13
On Hiatus
SY's Avatar
One thing I found out accidentally is that DN2540 will smoke if you don't power it up in just the right order. For a follower like this, the depletion mode doesn't carry much advantage, so you might think about switching to a more prosaic enhancement mode device.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 18th January 2008, 09:06 PM   #14
CAindoAUDIO is offline CAindoAUDIO  United Kingdom
Sheldon
But, it can be operated as an enhanced device > gate to source positive. Iguess something like 2 zeners to protect this FET ?
Old 18th January 2008, 09:12 PM   #15
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
Using a CCS as the grid 'leak' resistor for the 801A2 might be the reason for bias runaway. Try connecting a 100k resistor in parallel with the CCS, i.e. from the 801A2 grid to ground. This shouldn't materially affect the operation of the CCS but it will satisfy the maximum grid-cathode resistance requirement of the 8012A under fixed bias conditions. IF you're using a cathode bias resistor, a 470k grid 'leak' resistor will do.
Old 18th January 2008, 09:44 PM   #16
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Different capacitances cause different currents on highs through ground loops.
The Devil is not so terrible as his math model is!
Old 19th January 2008, 12:31 AM   #17
Thanks for the suggestions. I'll file them for future use (maybe even tomorrow). Wavebourn was onto something - an extra ground issue. The immediate problem seems to have been a partial short between one of the FET's and heat sink. No conduction when I assembled it, but maybe with heat expansion, a little burr dug its way through. I replaced a cooked FET, lapped them all along with the heat sink. Seems fine now.
I'll take a break and listen to music, then see if I can implement a plate CCS on the driver tube.
Sheldon
Old 19th January 2008, 12:35 AM   #18
Interesting. In this case, the bias voltages are all derived from the same supply, so come up quickly and essentially concurrently. The bias will lag the rails just a little because of the extra RC sections.
If if problem becomes a recurring issue, I guess I could use a regular Mosfet as the follower and a DN2540 for the current sink.
Sheldon
Old 19th January 2008, 01:33 AM   #19
On Hiatus
SY's Avatar
Default DN2540
In a cascode current source or sink, I've never lost one, and I've done a few dozen.
Old 21st January 2008, 08:13 PM   #20
You are right SY about these being touchy. I've lost a few now when I play with the amp under power. If everything is properly wired, I don't seem to have any issues. I've got the follower loaded with a resistor now, and it's fine limited swing. But I get significantly less distortion with the current source load when I try to swing more voltage, so I'm going to switch back. Interestingly, if I load the 6SN7 with a cascoded DN2540, the distortion increases slightly over the resistor load, even at larger voltage swing.
Sheldon
MOSFET follower driver oscillationHide this!Advertise here!
Does anyone has mosfet PP power follower schematic? bogdan_borko Solid State 0 11th December 2005 08:37 PM
Mosfet oscillation or not AndrewT Solid State 11 9th October 2004 09:45 PM
mosfet oscillation gustav Solid State 4 9th December 2003 08:46 PM
Driving a MOSFET power follower RichardJones Pass Labs 19 22nd July 2002 02:02 PM
MOSFET Power Follower help RichardJones Solid State 0 28th January 2002 06:01 PM
Copyright ©1999-2017 diyAudio
