| diyAudio Sponsor | ||
Hi people!
I have a simms-watts PA 100 head http://www.drtube.com/schematics/simms/100w-amp.gif , that im trying to convert in a guitar amp. I already turned off two tubes (OT still sees impedances), this softened the sound a bit.. I wonder if it is posible to convert the power amp in a triode mode. The plate voltage is around 500 V, I think this is too high. And should i conect the screens with 100 Ohm resistors too the plates? Any suggestions? |
#2 |
diyAudio Moderator Emeritus
Yes, 500v is much too high for triode operation, especially since that amp uses grid bias, so there is no voltage lost across cathode resistors. In fact, 500v is really too high for ultralinear operation too. EL34 screens are rated at 420v max. What you need to do is drop B+ to about 420v.
As you say, you can just connect the screens with 100 Ohm resistors to the plates and leave the UL taps on the OPT unconnected (and safely insulated). The OPT should still be a reasonable match for triode operation. Just watch the bias when you switch it on - set the two bias pots to maximum negative voltage (minimum current) and adjust from there. |
#3 |
Ray, in triode mode, Mullard's spec sheet indicates a 600V max for plate and g2.
od: Yes, a 100R screen stopper seems to be a good idea. And you'll certainly have restricted treble, but for this application, that may be fine.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
It already looks like a Fender's guitar amp's output stage. However, Fender preferred to connect the cap from the right grid to the earth instead of to the GNFB, for more musical overdrive.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 | |
#6 |
Yes, I think that 800V is pushing it a bit for octal bases.
Certainly in my guitar amp days I had enough trouble with arc-overs on valve bases in guitar amplifiers, most of which were running at around 440V. I suppose a clean ceramic or (wishful thinking) PTFE base would be OK, but very often the interiors of guitar amplifiers left something to be desired in respect of cleanliness! And the plastic octal bases were probably not ideal. 7N7
Plug them in and light them up |
#7 | |
#8 | |
7N7
#9 | |
#10 | |
7N7
| Converting Yarland FV-34AIII to Triode and Zero NF | jolon | Tubes / Valves | 4 | 11th January 2012 04:11 PM |
| Another 3f4 spice triode model: 5718 submini triode | wa2ise | Tubes / Valves | 0 | 5th September 2008 04:31 AM |
| PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode | percy | Tubes / Valves | 23 | 22nd January 2007 12:36 AM |
| Converting Bl | ht_boy | Multi-Way | 2 | 12th December 2005 04:32 AM |
| help converting conrad johnson MV-55 into triode! | nikos | Tubes / Valves | 2 | 19th June 2004 01:42 PM |
| Page generated in 0.10423 seconds (81.56% PHP - 18.44% MySQL) with 10 queries |
