help needed from the 300b crowd! help needed from the 300b crowd! - diyAudio
Old 20th February 2003, 09:33 PM   #1
Magnetmaz is offline Magnetmaz  United States
Magnetmaz's Avatar
Send a message via AIM to Magnetmaz
Default help needed from the 300b crowd!
Ok. I got my 300b amplifier.
Now : which brand of tube to buy?
Since this is my first set, and i'll probably bias them too hot and burn them out quick or something...i want to go with a lesser-cost brand... So WE is right out.
So : between Valve Art and ElectroHarmonix, who makes the better 300b ? ( i think these both go for about $40-50 each )
Are there better manufacturers that are in the same ballpark price range?
-Maz
Old 20th February 2003, 10:13 PM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
help needed from the 300b crowd! Send a message via AIM to Peter Daniel
How about this link?
http://www.stereophile.com/showarchives.cgi?229
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 21st February 2003, 12:14 AM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default 300B.
For the record Electro-Harmonix does NOT manufacture any type of tube.
My vote would go to the Svetlana 300B, not overpriced as the WE and a close copy nonetheless.
Frank
Old 21st February 2003, 02:52 AM   #4
Sylver300B is offline Sylver300B  Canada
Hello,
Here is another link for an equally interesting test about different 300Bs. By the way, there is no reason why you should "fry" your tubes, providing you take a few minutes to choose a proper bias/voltage setting. Your 300Bs should last long, very long. Enjoy!
Sylvain
Sylvain, Québec
Old 21st February 2003, 02:55 AM   #5
Default Oops!!
Here it is: http://www.enjoythemusic.com/magazin...ent/1201/300b/
Sylvain, Québec
Old 21st February 2003, 02:57 AM   #6
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Post a pic of your amp when you get it finished!
Old 21st February 2003, 03:03 AM   #7
Brett is offline Brett
Brett's Avatar
Default Another review
http://www.worldaudiodesign2.co.uk/p...5300bvalve.pdf
I have some of the EH 'Gold Grid' 300B's that I got a short while ago. They're not in a circuit yet so no comment on how they sound. If you hunt around, you can get them <i>much</i> cheaper than the MSRP.
Old 21st February 2003, 05:38 AM   #8
jeff mai is offline jeff mai  Australia
jeff mai's Avatar
I quite enjoyed the Valve Art 300Bs I had. I got them from Angela Instruments. I think they were the Angela branded ones.
Later I regretted keeping the Svetlanas in favor of the Valve Arts. The Svetlanas turned out to be weird and one has since failed, but that's my own fault. I bought them from someone selling them as factory new, but cheaply on eBay. I think they were rejects or seconds.
Old 21st February 2003, 07:49 AM   #9
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Jeff...
a lot of Svetlana's fail...
but if they last you past 6 months..they should keep you happy for quite a while.
Apparently there is something about the filament in the svets..heating up cooling down that breaks the filament as they contract and expand over the "thingies" that hold them in position.
Bas
Old 21st February 2003, 12:46 PM   #10
Tomatito is offline Tomatito
Default Dirt cheap
Just for experimenting you could buy a pair from this guy
kwtubes
his 300B's are only $25 and go for the more expensive stuff when you're satisfied with your measurements.
good luck
Martin
help needed from the 300b crowd!Hide this!Advertise here!
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
Eric Clapton - There's one in every crowd, value? Makofoed-6sn7 Music 4 8th May 2006 06:20 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
drd c3g/300b - help needed garbage Tubes / Valves 15 1st February 2005 11:33 AM
new digital amp aims at SE crowd? JRKO Class D 2 9th November 2004 08:54 AM
Copyright ©1999-2017 diyAudio
