| diyAudio Sponsor | ||
HI:
I want do a the 300 Bs of structure like this, which friend have already done? Thanks! China_vincent |
#2 |
If you build it as drawn, try bypassing the 3K3 resistor on the grid of the 300B wiht a clip lead and see how the sound changes. It is not needed for proper circuit operation.
dave |
#3 | |
Of more concern is the fact that the 417A needs to be handled very carefully when swinging these kinds of plate voltages as you will be swinging the grid over more or less its entire linear operating range and then some. I would use a 1:2 or 1:2.25 step up here - say 10K:40K/50K or similar. (Note that the driving source Z seen by the 300B with the proposed changes will be less than 10K with 1:2, less than 12K with 1:2.25 so HF BW will be ok.) I have designed and built choke loaded 417A/5842 to drive 71A - works really well, and sounds great. I've no doubt with the right IT you will achieve excellent results. I run the 417A at 15 - 20mA with 150V on the plate. (Approximately -1 to -1.2V fixed bias on the grid, varies a lot due to variations in GM from tube to tube.)
www.kta-hifi.net |
#4 |
The 100V rating of the cathode bypass cap seems a little marginal to me, especially if you're choosing an electrolytic. Lower ESR is obtained with higher voltage rated caps (which is easy to find in 220 uF).
#5 |
WE417-300B
#6 |
WE417-300B
#7 |
Looks very good.
Do you have an inside view? Kind regards, Darius |
#8 |
Darius, would you have a pair of RL12T15 sockets ?
#9 |
hi oldeurope,
will U considerate this circuit? 417a & 437a was close. thx thomas |
#10 |
Does anyone know what happened to Thomas of Diyaudio.hk (tube-lover)? He ripped me off to the tune of $800 on eBay for one of his amplifier kits.
John |
| FS: for 300B (JE Labs 300B SE) builders | cartman | Swap Meet | 2 | 29th October 2008 01:13 PM |
| sub out in my 300b se? Help me please. | fergs1 | Tubes / Valves | 1 | 4th December 2006 06:17 PM |
| WE417/437 with battery or RC on cathode | TBM | Tubes / Valves | 14 | 23rd May 2006 12:00 PM |
| * 35 watt * 300B SE = super 300B + Class A2 | rick57 | Tubes / Valves | 4 | 13th July 2005 04:18 PM |
| Drd 45, 300b | Angel Puerto | Tubes / Valves | 28 | 29th March 2005 03:02 PM |
| Page generated in 0.09915 seconds (79.46% PHP - 20.54% MySQL) with 11 queries |
