diyAudio Sponsor
Old 21st December 2007, 03:24 AM   #1
rdf is offline rdf  Canada
rdf's Avatar
Default DHT AC Filament Noise
The junkpile finally got large enough for a stab at the SE 813 or 828 in the plans for a couple of years. One of the remaining questions was how to handle the filaments. I started with the simplest and took at wide band look from centre tap to ground of an AC transformer driving an 813. No wonder some claim it has more 'life'. See below. Granted it wasn't hum balanced and some of the hash can be expected to cancel, this is still nasty. With the mains disconnected the measurement dropped to the -140 dB floor across the board so I have no doubt it's the real thing.
One for the files.
Ears aren't microphones.
Old 21st December 2007, 09:06 AM   #2
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Do you think these harmonics are present in the power lines due to industrial loads and/or SMPS? What would you get with a pure sine wave into the tube?
Interesting that there could actually be some truth to the "cleaner power" explanation of why tube amps sound better late at night...
Old 21st December 2007, 11:30 AM   #3
Majestic's Avatar
wow, that does look somewhat unpleasant.
What software/HW are you using to take those measurements, btw?
(newbie to DIY measurements, here)
check out my avitar and go easy on me ok? :-)
Old 21st December 2007, 02:56 PM   #4
rdf's Avatar
The spectrum above was taken right at the 10 volt secondary of the filament transformer, ground tied to centre tap. A measurement done afterwards from leg to leg was of course 6dB higher overall but otherwise the same. How much of it appears on the plate is naturally dependent on tube and circuit but it's unquestionably on the cathode. As to the cause, I suspect it's the transformer!
Here's why. I benched a very low distortion (0.02%) parafeed headphone amp using a toroidal 240 volt to 20 volt power transformer. The max plate swing into the primary is about 100 volts p-p. Curious how an EI transfomer would perform as an OPT I substituted the same Hammond filament transformer seen here, which is rated 120 volt to 10 volt. Since the voltage ratios are the same the headphone amp plate load should have been roughly equivalent. The distortion shot through the roof and displayed a very complex set of harmonics. The result got me curious about the Hammond in a filament application where it's getting near double the primary voltage and delivering real current. I'll leave it to the black art 'magnetmaticians' to comment on cause but I suspect the core material, i.e. Hammond strikes again.
The standard logic dictates that EI power transformers are preferable in audio partially due to higher internal losses acting to filter power line junk. Toroids are so effcieint and wide band everything passes straight through. As I so often find, the picture is much more complex when a meter enters it. This was intended to be a 'budget' 813SE but now I'm torn between Tentalab CCS filament supplies using these transformers or finding toroid 10 VAC trannies.
Majestic: The software is WaveSpectra 1.31 - http://www.ne.jp/asahi/fa/efu/soft/ws/ws.html - which was just recently updated to 1.40. In combination with Sinegen - http://e-cat.nm.ru/sinegen/ - it makes a great freeware PC suite.
Old 21st December 2007, 06:43 PM   #5
rdf's Avatar
In retrospect, noise was probably the wrong term. Filament mains distortion more accurately describes what I think is happening.
Old 22nd December 2007, 05:05 AM   #6
I performed some similar measurements, the results can be found here:
AC supply noise
The harmonics are originating from the mains and are the result of power supplies chopping of the top of the sine wave. If you chop the top of a sine wave it will start to look like a square wave. A square wave is made up of only odd harmonics and this is what you see in the spectrum.
If there is DC offset on the mains this can also create problems. Not all transformers can handle this which results in harmonics on the secondary, mechanical hum and heating of the transformer.
To minimize the noise on the heater supply I used a Lundahl mains transformer (with air gap to handle DC), a CRC filter and a MachMat VCCS. With this approach I got the noise on the heater down to 0.067mV.
Note: It is important how you measure the noise. If you use autobias the heater supply will float above ground, measuring unbalanced will skew the results. You have to measure the differential noise on the load.
See: DC heater supply part 4, Revenge of the Caps
Old 22nd December 2007, 11:59 AM   #7
работник
Rod Coleman's Avatar
Default AC is third best
Moving from ac filament supply to dc (current) is one of the most striking improvements possible in a DHT amplifier!
Here's how I implemented mine:
New DHT heater
Piotr Grzesik tried this circuit out on a linestage DHT amp, and compared it to other dc voltage and current implementations and reported "More life & energy, with a beautiful clarity!"
That's very much how it sounded to me. It's the cross-coupled transistor current source that really makes it work beautifully, far better than any IC-based solutions.
My pair of heaters has been in service with the same set of JJ 300Bs for three years now, and despite being purely current drive, the voltage accuracy is still 4.91V and 4.96V after this time.
Try Guido's module, or DIY one like this. I'll be doing circuit boards (bare PCBs) for it soon, it's really good enough to deserve a wider audience.
Old 22nd December 2007, 04:06 PM   #8
rdf's Avatar
Hi Gerrit. Your 'flat topping' comment piqued my curiousity. You're right, the AC waveform at the filament is highly distorted but I think we're saying the same thing when I ascribe it to a minimally spec'd core. In this case the Hammonds are rated for 8A and the 813 draw at 5A so it's not like it's running on the edge. An 828 draw 3 1/4A and will be tested later today. It might end up an 828 amp instead.
Old 22nd December 2007, 04:29 PM   #9
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
If you had DC on your mains, that could saturate your mains transformer.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 22nd December 2007, 04:53 PM   #10
rdf's Avatar
Good point. The mains DC offset is in the range of 3/4 volts. A 100uF motor run in series with the primary helps a tiny bit but the filament waveform is still highly distorted, roughly equivalent to a soft-clipped triangle wave.
Low noise transistor and noise figure Real_Macgyver Solid State 26 31st January 2011 01:34 PM
DHT filament PSU: What would you do? Fuling Tubes / Valves 11 15th September 2007 09:18 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
2A3 AC filament hum bigbulb Tubes / Valves 4 28th July 2005 12:59 AM
Page generated in 0.11795 seconds (84.27% PHP - 15.73% MySQL) with 11 queries
