| diyAudio Sponsor | ||
#21 | |
Official Court Jester
Wright (read - Tectronix) fer instance
my Papa is smarter than your Nelson ! tnx to |
#22 |
Tek actually used a three triode stack- a cathode CCS, the CF itself, and the upper bootstrap tube. They did a compensation trick there that I don't fully understand- I'll see if I can get a scan of a schematic posted.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#23 |
reason i asked is i have these 6336 tubes that i would like to do a CF power output using an MJW18020D as current source, i reckon this trannie has morre than 30watt SOA at Vce of around 150volts.......
actualy weighing in heatsink size, versus a PL504 tube as current sink... i thought the sandstate sink is cool..
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96 |
#24 |
Seems to me that a high gm pentode would be a perfect candidate for the follower job. Even if we wire it as a triode it should behave like a pentode thanks to the constant voltage on both screen grid and plate.
#25 | |
When I started down this CF output stage path six or eight months ago I new that I was going to use some type of constant voltage circuit. Thus I needed to find a tube that would work well with a fixed low voltage across it. I also wanted a tube that could handle a lot of current (hundreds of mA) so that I could use a low impedance OPT (600 ohms) and eventually do an SE OTL. I set up a test fixture and ran through a bunch of different tubes, captured data, and plotted the linearity VS current for a fixed voltage. The clear winner for this application was the 6336A. In second place a triode wired 6LW6. I did not test the Russian 6C33C since I do not have suitable sockets. If you want to experiment with CF output stages using 6336's stack your follower on top of the output CF and do an "augmented design". If you are not in a big hurry, I will post my schematics after I get it all working correctly. There will be a version with 6336's, but I will probably use a mosfet for the top device due to SOA failures with BJT's. I plan to run the total B+ in the 350 to 400 volt range to achieve 20 to 30 watts. I am enclosing the ACF-2 circuit from the Macdonald publication. I don't have much time since I am leaving town on the 26th but I have built one of these with the following changes. I substituted a CCS IC for V5, V1 - V2 is a 6SN7, and V3 - V4 is a 6AS7. It works, but I have not had time to do much testing. I could not get it to work with a 6SL7 for V1 - V2.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#26 | |
Allen Wright claims that its real sonic benefit is in removing the feedback element of the cathode resistor in a normal CF. Don't know myself There is a brief mention of the circuit over on the Tubcad archive, he implements a very interesting low voltage version using ECC86's, I think the B+ is only 24V. This removes practically all the complexity associated with this circuit approach and because of the extremely linear nature of this circuit - I would feel confident that it would give up little to a higher voltage version. I intend to do further refinements but am convinced in the approach. It presents an extremely uncoloured but mellow sound - which is exactly what I expect from valves. Shoog |
#27 | |
Were you able to find that Tek schematic? Dave |
#28 |
Maybe this?
Ohms Law V = I R |
#29 |
Sorry, Dave, I forgot. I've got it in my hands and will scan and post.
#30 |
That is an interesting circuit, what is the source? However, it isn't the Tek circuit that SY mentioned. From SY's post, it was a lot more complex.
Dave |
| cathode follower | vlljpior | Tubes / Valves | 6 | 22nd March 2005 08:50 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 07:47 PM |
| cathode follower | ackcheng | Tubes / Valves | 2 | 6th July 2004 04:12 PM |
| Cathode Follower? Yay or nay? | SHiFTY | Tubes / Valves | 25 | 16th March 2004 07:38 AM |
| cathode follower | olvrkrg | Tubes / Valves | 3 | 21st February 2004 10:49 PM |
| Page generated in 0.11567 seconds (78.24% PHP - 21.76% MySQL) with 11 queries |
