diyAudio Sponsor
Old 20th December 2007, 10:54 PM   #1
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Default figuring amplification factor of a tube
Hi guys it's been awhile, I know you can find the amplification factor by doing a little math I just don't remember how you do it can anyone remind me?
Thanks a mill,
Nick
Old 20th December 2007, 11:26 PM   #2
SY's Avatar
Easy. Look it up on the datasheet.
Otherwise, the mu is the slope of plate voltage change plotted against grid voltage change at constant plate current. If you have the curves in hand (but for some odd reason can't turn back a page to get the mu), lay a horizontal line across the curves at the planned current. Find the curve that's closest to the desired no-signal plate voltage and note the reguired grid voltage. Step over one curve and read off the plate voltage and note the grid voltage. Take the difference between the two plate voltages and divide it by the difference between the two grid voltages. Voila! You have mu.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 20th December 2007, 11:43 PM   #3
nhuwar's Avatar
Well the funny problem is the spec sheet for the tube besides the voltage a current limits only lists the mutual conductance and here's another shocker no graphs.
Thats why I asked and just in case you want to look it up the tube is a gu10a.
Nick
Old 20th December 2007, 11:51 PM   #4
nhuwar's Avatar
Oh I forgot to ask is the mutual conductance the same as the mu?
I have a strange feeling that it is and im going to feel a little stupid.
Nick
Old 21st December 2007, 12:12 AM   #5
SY's Avatar
They call it "gain coefficient" on the data sheet. 40-45.
Mutual conductance is the same as transconductance, i.e., it's the change in plate current with change in grid voltage, at constant plate voltage. Mu is the product of transconductance and plate resistance.
Old 21st December 2007, 12:16 AM   #6
nhuwar's Avatar
Ah I didn't know it was that thanks SY
But as you can see there isn't a lot of data of the spec sheet.
Thanks,
Nick
Old 21st December 2007, 10:29 AM   #7
Yvesm is offline Yvesm  France
Yvesm's Avatar
Hi Nick,
When you have plate curves, you have all !
In attached one (It's a Russian 6N6pi)
Pick a first point on a grid line, f.e. the red one where Vg is -4V, Vp is +155V and Ip is 30mA
Move down vertically (constant plate voltage) till you cross another grid line (the blue dot).
Here Vg is -6V and Ip is 12 mA.
That means that plate current change is (30 -12) 18mA for Vg change of 2 Volts.
Thus the slope is (18 / 2) 9mA per Volt, the same that a transcondustance of 9000 if expressed in mmoh.
Then, move left horizontally (constant plate current) till you meet the original grid line (green dot).
The plate voltage is now 120V for a 2V grid voltage difference, thus the Mu, µ or amplification coefficient is (155-120) / 2 = 17.5
The Rp is figured by the slope of a straight line joining the red and the grid dot.
This is the same as dividing the Mu by the slope (in Ampere per Volt), here 17.5/.009 = 1K94.
<edit>
Oopps, misread the plate voltage !
</edit>
Yves.
Old 21st December 2007, 11:11 PM   #8
nhuwar's Avatar
I know I wish the tube spec sheet had them. I have faced the facts and relised I will had to use the data I have from the data sheet and try to make my self a plate current per plate volt by grid voltage chart my self.
SY don't worry I am not thinking of using this tube for a audio amp.
Nick
Old 21st December 2007, 11:23 PM   #9
SY's Avatar
Actually, it looks perfect for something Pete Millet and I have been bandying around...
Old 22nd December 2007, 12:36 AM   #10
nhuwar's Avatar
Sy you got style.
Nick
Figuring out how many watts I need Chepo Tubes / Valves 6 9th June 2009 12:43 AM
s5electronics tube amp kit damping factor ben106 Tubes / Valves 9 26th September 2007 09:42 AM
Help with tube amplification? SashaV Tubes / Valves 4 20th February 2006 04:04 AM
Who is into musical instrument tube amplification? elementx Tubes / Valves 15 29th August 2005 09:38 PM
Bogen tube amp with variable Damping Factor viatatto Tubes / Valves 0 26th August 2005 11:35 PM
Page generated in 0.10151 seconds (77.72% PHP - 22.28% MySQL) with 11 queries
