| diyAudio Sponsor | ||
Got som problem with connecting this to the amp because i see that the colorcoding of the wires on the new transformer doesn't seem to be the same s on the old one's...
Could this transformer possibly an 120v version, and if so... Is it possible for me to convert it into an 240v? Andreas
Tubes, horns & DIY.. |
#2 |
Where did you get it from ?
If you got it from a shop, they must have the wiring color scheme... Isn't there any label on it ?? Maybe a photo here can help identify the colors
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
I got it from Troide Electronics in the U.S.
The thing is that, after i had got the package (it's containing maintransformer, 2 output transformers and a choke) i found out that the firm sold a 240v transformer which gave me a little scare. That there might be a chance that so is. The scheme which i downloaded from TE shows this 117v, which confirms my suspicon. I can put in pictures and schemes (dynaco and transformer) in 30 mins...
#4 |
new transformer
#5 |
If it has a purple and purple/white lead then it is the export version. This version can be wired for a 117v or 240v primary but you need to join the primary leads together in different ways to achieve this. I used to have a wiring diagram for this transformer and will continue to look. In the meantime, email Matt at Triode, he will send you a wiring diagram - they are very good over there. Cheers, Rob |
#6 |
VS. old..
#7 |
Here we are...
#8 |
Ah....
Thanx a lot, Rob! I will do so Started to get a bit anxious if i have to replace the transformer with a 240v type.. Good to know! Thanx again! Andreas btw... put in a picture of it with the old ones
#9 |
So it looks like you have the export version. I have used it myself and it seems to be a fine transformer. Good luck, hope that it works out OK. Cheers, Rob |
#10 |
Thnx again, Rob..
But since there are no purple leads or any who look like purple except black i'm still a little lost, but i'm going to ask Matt at TE and see if they got any "schematics for dummies" to e-mail me
| Dynaco Pas Transformer | jesserparker | Tubes / Valves | 2 | 3rd September 2008 04:28 AM |
| MQ431 or Triode's DynaClone | rlaury | Tubes / Valves | 5 | 22nd December 2005 04:43 AM |
| Dynaco ST150 PS Transformer | Dick West | Swap Meet | 8 | 10th July 2005 02:40 PM |
| May I use 5K transformer for Dynaco III amp? | audionote | Tubes / Valves | 3 | 16th May 2004 03:57 AM |
| Page generated in 0.09263 seconds (81.03% PHP - 18.97% MySQL) with 11 queries |
