diyAudio Sponsor
Old 20th December 2007, 07:46 PM   #11
Now I ordered two of these AD5290, I will give them a chance....
Old 20th December 2007, 07:54 PM   #12
kevinkr's Avatar
Originally posted by tubeeater
Thanx, I have to try this.....
My doubts are that the AD5290 won't survive the poweron, since at this moment the caps that filter the HV are not charged and the whole HV hits the chip, but I will do some simulations.... I will post when done.
<snip>..
Use diode clamps on the inputs as I previously mentioned.
www.kta-hifi.net
Old 20th December 2007, 07:54 PM   #13
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
8 FETs and 8 resistors for one 8 bit variable resistor - what may be simpler? You may add 8 D-triggers to lock up the state.
Also, it does not harm the sound unlike ICs with active VCAs.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 21st December 2007, 12:08 PM   #14
Thanks, I will try that also.... I just have to get the parts
I will try both the chip and the FET / resistor version and compare it...
By the way: my simulations show that I have some signal level of +- 40V something... I will have to stack 3 of the chips but it seems to be possible tough...
incorporating tone control ckt on power amps nfb audiomachines Solid State 0 11th February 2009 10:49 AM
quality tone/volume control space2000 Solid State 6 13th March 2008 02:47 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
tube tone control? JojoD818 Tubes / Valves 20 18th January 2006 11:32 PM
digital pot for tone control? demons_wing Chip Amps 4 25th May 2005 09:22 AM
Page generated in 0.06845 seconds (73.27% PHP - 26.73% MySQL) with 11 queries
