diyAudio Sponsor
Old 20th February 2003, 02:05 PM   #1
Zombie is offline Zombie  Sweden
Question QUAD II mains at 240VAC instead of 220VAC?
Hello!
My Quad II's go awfully hot and the xformer pit is flowing. The voltages at the measuring points are 10-15% higher than the nominal.
Would connecting the mains to the 240V (ca. 10% decrease in the voltage input) tap make the amps run less warm?
Any hazards?
Tom
Old 20th February 2003, 04:03 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Hot Quads
Quad IIs always run rather hot, but they shouldn't be melting their pitch! There is no hazard at all in setting them to the 240V tapping rather than 220V - quite the reverse. And yes, it should make them run cooler.
Once done, check the HT voltage to the output stage against the specified voltage, and check that the 180R cathode resistor isn't on the verge of dying.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 20th February 2003, 04:08 PM   #3
Default Voltages
Hello!
Thanx for the reply.
I just switched them on (some other people assured me it's OK to change taps) and here's what I've got:
323V before the choke
316V after the choke
24V on the 180R
All other voltages as before.
Do you see anything potentially damaging here? Or (even worse) sonically deteriorating?
Btw, I had 360V at the choke before...
Tom
Old 20th February 2003, 04:28 PM   #4
EC8010's Avatar
Your voltages are all 5% down on the Quad specified values, but that's unlikely to cause an audible problem, and your mains voltage variation might be as much as that anyway.
If it hasn't been done already, it's a good idea to replace the 180R 3W resistor with a 5W type, and also replace its parallel capacitor (the heat shortens its life).
Keep an eye on transformer temperature, although replacements can be had, they are expensive. I assume that you have left plenty of room around the amplifiers for cooling...
Old 20th February 2003, 04:59 PM   #5
Yup, I have a 5W 180R now, and a 47uF in paralell.
Seems it doesn't go that hot anymore, but I'll let it run the rest of the evening. No change in sound though...
Tom
240Vac mains isolation transformer AndrewT Everything Else 13 26th September 2007 07:10 AM
Quad 405 mains transformer? Confussed Solid State 2 14th August 2007 06:12 PM
BBC modded Quad 405s - mains hum spwyatt Solid State 4 2nd October 2006 09:18 AM
Quad ESL 57 mains voltage problem rob_deas Planars & Exotics 2 21st February 2005 04:37 PM
Quad II mains transformer 405man Swap Meet 1 19th January 2004 05:49 PM
Page generated in 0.07592 seconds (78.41% PHP - 21.59% MySQL) with 10 queries
