EF86-EL84: too much gain!
Old 18th December 2007, 06:01 AM   #1
pftrvlr is offline pftrvlr  United States
Default EF86-EL84: too much gain!
I spent the last week modifying a 12ax7-el84 headphone amp. The major change is replacing the 12ax7 with ef86 and getting ride of the nfb. The project went fine and the amp is now working fine. There are still a few things I want to improve. The first one is I need to reduce the gain. It is way too sensitve to vol control and the normal listening level is at 9 o'clock.
I want to keep the idle current (ef86 @ 1.8ma, el84@35ma) as it is. Any suggestion as to reduce the overall gain? The schematic is below:
Old 18th December 2007, 06:13 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
My current amps are similar, but the EL84s are wired in pentode, and there is plate to plate feedback (search for RH84 here and on the net). more than twice the power and at least similar quality sonics.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th December 2007, 06:33 AM   #3
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Default Re: EF86-EL84: too much gain!
The lack of a cathode bypass caps implies some local nfb. Whether this is bad or not is up to you, but it is there (and it reduces gain.)
Anyhow, you could swap the output tubes for some 12B4's, or you could shunt the volume pot by putting a resistor (about equal to the pot resistance) in series with the pot's input. Or you could add a resistor connecting C8 with R20 to build a voltage divider (which is similar to the shunted pot, just in a different place). Lower R20 to 500K and use a 500K for the series resistor. Or, you could just drop the driver altogether -- not sure why you would need it for a headphone amp.
Old 18th December 2007, 09:54 AM   #4
engels is offline engels  Israel
engels's Avatar
Default Re: Re: EF86-EL84: too much gain!
Originally posted by dsavitsk
Lower R20 to 500K
Old 18th December 2007, 07:09 PM   #5
Thanks guys.
When I said I got rod of the NFB, I mean the global NFB. I add the local NFB intentionally to reduce the gain of each stage.
I will do some PSPICE sim of the RH84 to see how it work out.
Old 19th December 2007, 09:17 PM   #6
GordonW is offline GordonW  United States
GordonW's Avatar
One other idea- try running the EF86 in triode mode. This will drop the gain significantly.
Of course, this will also increase the Miller capacitance of the input. However, with low-gain settings on the EF86, this shouldn't be much of a problem, if any...
Gordon.
Speaker Design, Restoration and Repair- since 1985.
Old 19th December 2007, 09:32 PM   #7
frugal-phile(tm)
planet10's Avatar
According to his schema he already is...
dave
Old 19th December 2007, 09:37 PM   #8
dsavitsk's Avatar
In the end, it is odd to use a high gain tube, and then complain that you have too much gain. There are plenty of other choices out there that will solve the problem.
Old 19th December 2007, 10:09 PM   #9
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Congratulations;
replacing the tube you got more gain so GNFB may be deeper now that means less distortions and better sound if to compare against "slight" GNFB that is enough to make a specter of distortions wider, but is not enough to bring level of distortions down. A negative feedback in tube amps is such sharp thing so you have only 2 options: use it as deep as possible, or do not use at all. To prevent oscillations you may need an additional minimal possible capacitor from anode of the 2'nd toob to cathode of the 1'st.
The Devil is not so terrible as his math model is!
EF86-EL84: too much gain!Hide this!Advertise here!
El84/6bq5/ecc83 + Ef86 = Dc Pp jackinnj Tubes / Valves 12 24th May 2017 08:29 PM
EF86 trancy Tubes / Valves 51 16th February 2015 09:37 AM
EF86 - Interstage transformer - EL84 PP AB Joao Pedro Tubes / Valves 9 10th January 2009 05:46 PM
EL84 + EF86 takashi Tubes / Valves 10 28th March 2008 02:30 PM
EF86 Gm dsavitsk Tubes / Valves 7 31st March 2007 07:59 PM
Copyright ©1999-2017 diyAudio
