| diyAudio Sponsor | ||
#11 |
#12 |
My values are similar. Here is what I have had great luck with:
R1 - 68k Bass pot - 500k LIN R3 - 100k switch to ground for mid boost C2 - 500pF C3 - .0047uF R2 - 200k C1 - 680pF C4 - .001uF Treb Pot - 500k LIN There has been a lot of experimentation from a few of the members at www.el34world.com Search their archives for "James" or "Baxandall" (many threads were misnamed). They have also posted a number of schematics under their schematics board. d1 |
#13 |
Depending on inflection points and boost/cut required you might even want to try a baxandall based tone control circuit. It's quite tweakable even for mi applications.
www.kta-hifi.net |
#14 |
I'm in the process of ordering parts for a James (Baxandall) tone stack, but am stuck on getting the right values and being able to order only one.
Adam's components can be purchased from Antique, but the caps come in bags of five. I've checked a few other places (Hoffman, Torres) and a few other stacks (diCamero's and TubeNit's), but am finding that they don't sell all the right cap values. On the other hand, I did a bunch of improvements:
The amp sounds really nice! |
#15 |
I'm wondering what the best tube and resistor values would be for V2, the last preamp stage and cathodyne phase inverter. Currently I have a 12AU7, which seems to work better than the 12AX7. There's more than enough gain already.
The first thing you'll notice is that the resistor values are unusual: 100K for the phase inverter and 360K/4.7K for the gain stage. I plan on changing to 56K for the PI (the values used in a 5e3). From my limited knowledge, 12AU7 has lower resistance and can supply more current that the AT or AX. The AT has the same resistance as the AX and can also supply more current, which may make it the best choice for the combined role. The 12AT7 would also be better off with 220K/2.2K or 100K/1.5K for the preamp gain stage resistors. Does this sound right? I'm seeing the need for an advanced book on tube amp design, although I do have several from the web, including Norman Crowhurst's articles. Any suggestions would be greatly appreciated. Thanks!! |
#16 |
diyAudio Moderator Emeritus
12AU7 would probably do a good job of driving the tone stack. I didn't recommend it because it's a non-linear tube but, for a guitar amp, it may be acceptable - it's up to you whether you like it or not. A better choice with similar plate resistance and gain IMHO would be either 6CG7 or 6FQ7 but you would need to rewire the socket because the pinout is different.
If you want a good reference book, 'Valve Amplifiers' by Morgan Jones (3rd edition) is my personal favourite. He's written it to be user friendly but, like any book, it doesn't cover every topic. Web sites I've found useful include Aiken Amps, Duncan Amps, The James-Baxandall Passive Tone-Control Network and Max Robinson's Fun with Tubes. |
#17 | |
As much as I admire Crowhurst, his writings are oriented entirely towards hifi and are not really a source of good information for anything other than tube based acoustic guitar amplifiers. Much better to avail yourself of the very specialized knowledge accrued specifically in MI amplifier design. The original Fender sound was an "accident," what grew from that was not.
www.kta-hifi.net |
#18 |
I've named this amp the Jazz Tank, because the name fits.
The steel case is covered in tweed, and it has a very thick steel chassis, which means it is extremely sturdy (i.e. built like a tank). There are four teflon and one paper-in-oil coupling capacitors. Those HiFi caps and the 7868 output tubes gives this amp a unique sound. I'm waiting for parts to make the James tone stack suitable for guitar. I also have to add a handle and feet. I could put in a leather handle, but it is a bit heavy. Here's the Jazz Tank web page http://www.naturdoctor.com/Chapters/Amps/JazzTank.html PS I wonder if this is the first tweed metal amp (i.e. a metal case covered in tweed). |
| Passive 2 band tone stack for guitar | SouPortugues | Instruments and Amps | 9 | 11th August 2009 03:35 PM |
| Tone Stack Challenge | cservonyec | Tubes / Valves | 13 | 3rd April 2009 01:51 PM |
| replacing tone stack in tube pa for guitar | blindbrett | Instruments and Amps | 5 | 6th July 2008 09:13 PM |
| Tone Stack Calculator or tsc ??????? | prorms | Solid State | 9 | 21st December 2006 03:33 PM |
| Feedback resistor on Baxandall tone stack? | porkchop61 | Tubes / Valves | 3 | 10th October 2004 02:39 PM |
| Page generated in 0.10801 seconds (80.32% PHP - 19.68% MySQL) with 11 queries |
