monoblock vs. one chassis?
Old 31st March 2003, 03:17 PM   #21
siu sin man tho is offline siu sin man tho
Account Disabled
agree, short speaker cable & long signal wire.
the sound will less hifi & more natural.
the reason is the long signal wire had a large capacitor with lost high freq, so the sound will less hifi. But BTW more natural is this method.
I use 30 ft signal cable & 10 feet speaker cable.
thanks
Thomas
Old 31st March 2003, 03:21 PM   #22
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Yes, but...
Monoblocks almost double the metalwork. If you can keep the weight to below 60ilbs, it's easier to build on one chassis.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 31st March 2003, 03:39 PM   #23
Fantastic is offline Fantastic
Default But............
I know the chassis issue is there. But here the issue being considered is which cable should be longer. We aren't even considering the chassis which incidentally gets bigger and is not the problem.
I am sure we would make any chassis that fits the bill if we decide that one cable should be longer than the other.
Finally its left to the builder ... no matter what is really better.
If my wife will kill me if I have two chassis , I will build only one even if the speaker wire should be as short as possible. If not I will be 'shot'. Boy , is man weaker than a woman!!!!!!!!!!!!!!!
More
Fantastic
Old 31st March 2003, 03:53 PM   #24
joensd is offline joensd  Germany
I know there are more points to discuss about monoblocks than just the stereo separation but when it comes to that a lot of serious amp designers would comment to watch the PSRR and the proper grounding of your amp first than just "jumping" over these problems with monoblock construction.
I think itīs not right to believe monoblocks are better in general.
If you canīt properly build a stereo amp into one chassis you shouldnīt go monoblock unless you use a topology with poor PSRR like some simple Class A designs so you kinda depend on power supply separation.
Jens
Old 31st March 2003, 05:21 PM   #25
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default The new tip...add capacitance to the interconect...
So, the less high frequency, the better the sound??'
Oh my God!!
Why not to add a capacitor across the live and ground of the interconect to kill the highs and increase the distortion of whatever is driving it!!!
Maybe a new tip!!!
I think that i need some holidays
Jorge
Old 31st March 2003, 07:14 PM   #26
Default Less hf..........good
Hi Jorge,
I think this is a language problem. I think what was meant is that the HF will roll off.......outside the audio range and ensure that no ultrasonic noise etc will get into the system.
With a 600 ohm load ( properly driven )and with the cable capacitance of say 220pf per meter and 20 meters of cable the
-3db point is about 60KHz. Not too bad!
Fantastic
Old 31st March 2003, 10:16 PM   #27
Account Disabled
hi tube-dude & fantastic,
sorry my english is not good. I means not the high freq will lost many, Olny means the High freq will roll of a little bit more.
So the sound will hear less hifi, less sandy stone. More natural.
Hope U will understand what I mean.
thanks
Thomas
Old 1st April 2003, 11:28 AM   #28
Burnedfingers is offline Burnedfingers  United States
I guess the real proof is in the pudding. Audition a set of mono block amps against a single chassis amp of about the same output rating and make the call. I listened to a highly moded AES amplifier against a set of bone stock Quicksilver amps. The "Quickeys" blew away the AES's.
Sure you have two sets of everything to purchase when you put together a set of mono block amps. Like "Frank" always says "There are no free lunches"
Bottom line is you get what you pay for in this hobby/obsession. You don't get good low end with a 25 dollar output transformer or high fidelity with a 2dollar tube.
Just my .02
Joe
Old 1st April 2003, 12:55 PM   #29
Brett is offline Brett
Brett's Avatar
Hardly a relevant comparison. They're two different amps.
Old 1st April 2003, 02:22 PM   #30
Default Cost comparisons......
This is not strictly true. I bought Soviet 6SN7's (NOS) for about US$0.70 each ! That did not make them any worse than the same type tubes for US$5 or 8 in the US. It's just that the market where I bought it was getting rid of them.
Also used and old but perfectly good transformers could cost US$25/- or less at a sale. But bought from a dealer non of these would ever come so cheap.
You must be refering to prices at regular dealers. That's why I guess we find so many DIY'ers at garage sales .My friend bought a Thorens TD124AB with a 9 inch SME arm for US$25 /- !!!! All in perfectly good condition.
So don't ignore garage sales !
Cheers.
Fantastic
monoblock vs. one chassis?Hide this!Advertise here!
Class-A Monoblock Amplifier Chassis (qty 2) tstrafford Swap Meet 8 14th February 2009 05:19 PM
Chassis for DIY MonoBlock Tube Amplifier sgerus Swap Meet 1 20th January 2009 07:40 PM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 04:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 05:37 PM
Copyright ©1999-2017 diyAudio
