monoblock vs. one chassis?
Old 20th February 2003, 02:03 AM   #11
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default URBAN MYTHS.
I guess monoblocks can cause a ground loop problem.
Nah, only if designed wrongly.
I have used monoblocks (physically two separate chasis) for poweramps and have never experienced any problem with them.
My preamp is dual mono, not two monoblocks, so ground is common to both channels.
Monoblock design should be superior to integrated left and right channel.
Frank
Old 20th February 2003, 02:22 AM   #12
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally posted by Ryder
I've read where it works to keep the safety ground connected to the poweramps chassis (safety first)- but "float" the signal ground above the chassis gnd with a decent sized (min. 2W) 10-50 ohm resistor
What works best??
Getting rid of that damned AC power supply, that's what.
Actually, the method you mention above can be effective, though I prefer placing a 0.01uF cap in series with the resistor. That provides greater isolation at power line frequencies and the cap alows for a low impedance path to the chassis at high frequencies so that the chassis can work well as an electrostatic shield.
se
Old 20th February 2003, 02:28 AM   #13
fdegrove's Avatar
Default AC GROUNDING.
Absolutely, this method has been used for what...fifty years already?
Clever little trick,that one.
Frank
Old 20th February 2003, 02:42 AM   #14
Steve Eddy's Avatar
Default Re: AC GROUNDING.
Wouldn't surprise me. I first saw it at least 20 years ago.
Yup. Another clever trick (short of ditching the AC power supply completely) is to use a Class II double insulated chassis and ditch the !@#$% safety ground.
Sadly, there are probably a lot of commercial products out there whose chassis meet Class II specs but because the 3 conductor power cord has become so ubiquitous, the manufacturers just tack on an IEC socket out of habit and to be compatable with all the aftermarket IEC power cords.
se
Old 20th February 2003, 02:49 AM   #15
fdegrove's Avatar
Default DITCHING THE EARTH.
No big deal for a DIYer though.
As long as you play it safe,easy enough to solve IMO.
Frank
Old 20th February 2003, 03:15 AM   #16
Brett is offline Brett
Brett's Avatar
Wow, what an idea. My monoblocks are looking like weighing about 50kg ea when the chassis are finished, so if I go battery power to give me 900V, maybe I'll just add on an extra room for them all. Seventy four truck batteries if I want to keep them monos. Batteries R us are gonna love me. No one light a match when they're recharging.
Old 20th February 2003, 03:29 AM   #17
Steve Eddy's Avatar
That's the spirit!
se
Old 20th February 2003, 07:04 AM   #18
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Default Re: URBAN MYTHS.
I think in fact it's technical impossible to get ground loop problems if the monoblocks don't have protective earth. But you can surely get hum. I think everyone can agree that monoblocks are the easiest way to get problem free amps.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 8 pcb's in interest so far.
Old 31st March 2003, 01:42 PM   #19
siu sin man tho is offline siu sin man tho
Account Disabled
But pls remember that in one chassis if u use full triode version to push 300B. very easy to cross the noise.
this is the problem must be careful to handle.
If U like to use one chassis but near monoblock powerful swing.
one power trans with use seperate chokes ( every channel use one choke) & rectifier cap.
this will better.
thanks
Thomas
Old 31st March 2003, 03:08 PM   #20
Fantastic is offline Fantastic
Default Which is better.
Shorter speaker cables yes. - But then your interconnects would be eaqualy longer. I don't know which is worst.
I would say probably the shorter speaker cables are better. They are more difficult to have ( heavy) shielded braids with low impedance and generally their dc resistance will be lower if they are shorter.
For balanced low level signal lines especially at 600 ohms , frequency response, damping (?) shielding etc will be much better.
So I hazzard a guess that this might be a better way to go. It also avoids the ground loops mentioned earlier - or can be avoided with careful planning.
Balanced lines here we come !
Fantastic
monoblock vs. one chassis?Hide this!Advertise here!
Class-A Monoblock Amplifier Chassis (qty 2) tstrafford Swap Meet 8 14th February 2009 05:19 PM
Chassis for DIY MonoBlock Tube Amplifier sgerus Swap Meet 1 20th January 2009 07:40 PM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 04:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 05:37 PM
Copyright ©1999-2017 diyAudio
