diyAudio Sponsor
Old 14th December 2007, 07:22 AM   #1
Send a message via AIM to gibsonripper
Default Help designing Class-A, tube, transformer coupled, studio grade pre-amp
I'm wondering if anyone has advice or experience on the following subjects.
First, I'd like to point out that I'd like to try building an all tube, transformer coupled, Class-A pre-amp using NO CAPACITORS in the signal path. However, this doesn't mean I won't use them, if need be. I am willing to spend extra $$ on an additional intermediate transformer stage (if necessary) in order to eliminate any coupling caps that would normally be in place with a standard pre-amp design.
One of the biggest challenges is the output transformer interfacing with the last amplification stage. Jensen transformer company says that none of their transformers can be used as configured for a direct plate driven transformer (having the plate current run through it) without a coupling capacitor--which then would be a standard, more common design. I was hoping to replace the plate resistor for the final tube stage with a transformer, thereby eliminating an output coupling capacitor.
Regardless, I would still conisder a circuit design that DOES use caps. Does anyone also know of (or have a schematic for) a high-end tube pre-amp design (like UniversalAudio (LA610 or Solo610 ?) or a Hamptone tube preamp, etc.)?
Thanks very much for any feedback or suggestions.
Old 14th December 2007, 07:32 AM   #2
This is my current project. It is in norwegian, but you can look at the schematics. Not shure what u mean by "studio grade", this is for my home system.
The low rolls of a bit early, and the gain is a little bit high for a preamp but I hope to get by without to much troble.
There is an inductor in the filament supply and you do not need it. I think of it as an experiment.
http://www.hifisentralen.no/forum/in...c,17478.0.html
Old 14th December 2007, 07:59 AM   #3
aletheian's Avatar
Do some poking around the prodigy-pro forum (especially the Meta-Meta sticky), and i think you will find more information then you will know what to do with.
Heghlu'meH QaQ jajvam!
Old 14th December 2007, 08:17 AM   #4
Gordy is offline Gordy  United Kingdom
Default Re: Help designing Class-A, tube, transformer coupled, studio grade pre-amp
I understand your sentiment, however a transformer in the position you describe simply relies upon the last power supply capacitor for the true signal path, and that is likely to be a so-so electrolytic. Perhaps better to design it para-feed as the capacitor involved will be smaller than the power supply electrolytic and can then be a decent quality item. Also, if you go para-feed then I understand that the plate resistor can be replaced by a constant current source hence very much reducing the influence of the power supply capacitor.
As an idea, if you still want to go single ended then consider trying Kevin's (KTA-hifi.net) DHT 26 line stage plus a transformer coupled input. Here you go: http://www.kta-hifi.net/projects/pre...26dhtpre-1.pdf
(I also second the recommendation to look over at Prodigy Pro)
Old 14th December 2007, 11:27 AM   #5
"Studio grade" means an output imedance < 50 Ohms, only with transformers you don't reach this (you're needing feedback).
Best regards
Andreas
Old 14th December 2007, 01:32 PM   #6
JoshK is offline JoshK  United States
Take a look at the Raven preamp on nutshellhifi.com. Its a preamp designed by Lynn Olson and Gary Pimm. It fits your goals and I think you might even get close to your target Zout without NFB.
Old 14th December 2007, 01:37 PM   #7
link
schematic
Old 14th December 2007, 04:14 PM   #8
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Check out Edcor interstage transformers. Their resonably priced, made in the US and I've never heard a negative thing about them. They don't have any permissable DC rating listed on their products though.
Old 14th December 2007, 09:02 PM   #9
kevinkr's Avatar
Llundahl and Sowter both make interstage and plate to line transformers intended to carry plate current.
Jack Elliano over at Electra-Print will make you whatever you want once you know what it is.
The parafeed suggestion is a good one as well, but will require a single coupling cap.
www.kta-hifi.net
Class A2 Direct MOSFET Coupled SE Michael Koster Tubes / Valves 90 20th May 2012 03:14 PM
6sn7 direct coupled and transformer coupled neazoi Tubes / Valves 3 23rd May 2008 03:30 PM
Designing Transformer-Coupled Circuits... korneluk Tubes / Valves 0 14th December 2006 12:38 AM
What is an 'audio-grade' toroidal transformer ? ash_dac Power Supplies 7 5th September 2006 05:16 PM
FS: Hospital Grade Isolation Transformer - 3500VA - 6 outlets PaulHilgeman Swap Meet 2 12th June 2003 09:35 PM
Page generated in 0.10129 seconds (79.69% PHP - 20.31% MySQL) with 10 queries
