diyAudio Sponsor
Old 14th December 2007, 03:10 AM   #1
sorenj07's Avatar
Default EL84 Triode PP Design
I have the EL84's, the OPT's, and the 6N23P's are on the way.
Power supply:
Hammond 273BX (350-0-350 175mA) rectified by two UF4007 per leg bypassed by .1uF 1KV, into 193M choke (10H 300mA 63 ohms) and 440uF 450V cap, bypassed with 1uF 630V, feeding B+. B++ taps off a 20H 20mA 1.67K and 100uF 400V bypassed with another 1uF 630V, for the two 6mA regulators at 275V. The C- supply is a voltage doubler running off the unused 5A tap.
Old 14th December 2007, 04:00 AM   #2
SY's Avatar
You've got a negative rail there, why not use it and do a better CCS tail for the input stage- or at least give the one you have a bit more headroom?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th December 2007, 05:51 AM   #3
sorenj07's Avatar
Could I just connect the -15v supply right to the LM334 as it is?
Old 14th December 2007, 11:27 AM   #4
SY's Avatar
I don't know its voltage rating off the top of my head, but if that's within it, then yes, and that will give the CCS a little more breathing room.
Old 14th December 2007, 11:41 AM   #5
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
He can bypass the LM CCS with a good lytic cap to increase quality, can't he? Better off with DC duty on such a CCS only?
Old 14th December 2007, 12:27 PM   #6
SY's Avatar
If he doesn't want the phase splitter to function, then sure, he can bypass the tail CCS.
Old 14th December 2007, 12:55 PM   #7
Salas's Avatar
Blunder. DC only works in SE.
Old 14th December 2007, 01:05 PM   #8
Salas's Avatar
But how it works in Baby Huey? Is it partial?
Old 14th December 2007, 01:13 PM   #9
SY's Avatar
It's only bypassing the reference string, not the CCS terminal (the collector of the "upper" transistor).
Old 14th December 2007, 01:22 PM   #10
Salas's Avatar
Must be sounding better this partial thing. I have to check it out in mine.
EL84 fixed bias PP Triode DrewP Tubes / Valves 19 21st August 2008 06:51 AM
My EL84 Triode PP Amp sorenj07 Swap Meet 7 19th June 2008 04:13 PM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
triode => I.T. =>el84 good idea ? Jaap Tubes / Valves 9 7th January 2003 07:30 PM
Page generated in 0.09759 seconds (74.33% PHP - 25.67% MySQL) with 11 queries
