| diyAudio Sponsor | ||
DIY !
Hi
I have a pair OP trafos; OPT-102, from Audio Electronic Supply ( http://www.audioelectronicsupply.com/ ) but they are no longer listed. And my mails to them bounces... Are they known? Good? Arne K
Ars longa, vita brevis |
#2 |
AES is owned by Cary Audio -- try calling or emailing them.
http://www.ecpaudio.com |
#3 |
DIY !
Found these again, an did some measuring;
Primary : B+ to plate; 75+ohm (plate to plate:150+ohm) Sec: ~0,4(-)+0,4(-) (8ohm tap less than 1 ohm) Used my signal-generator to feed the sec.(8 ohm tap) with 5V (500hz), and measured 45V + 45V (90V) on primary. Does this make the trafo 90/5= 18:1? -or 45/5=9:1? Arne K
#4 |
My AES catalog from 1994 lists the OPT-102 as a 25 Watt PP with a 6600 Ohm primary imp. However with your measurements I calculate that it is only 2592 Ohms! Primary volts divided by secondary volts, square that and then multiply by the secondary Ohms. 90/5=18, 18x18=324, 324x8=2592. If it is supposed to be 6600 Ohms, the voltage ratio should be approx. 28.7. Check your readings again.
Craig |
#5 |
DIY !
So I tried other way around: 233V in A-A, gives 12,8V out on 8 ohm tap. This gives the same ratio...
Arne K
| NEC Audio amp data | coloradosound | Parts | 1 | 31st October 2008 03:47 PM |
| Audio Electronic Supply AE-25DJH | no xo | Tubes / Valves | 4 | 28th June 2006 02:36 AM |
| Antique Electronic Supply | Cambe | Tubes / Valves | 3 | 26th May 2006 11:43 PM |
| need audio electronic service | sma | Parts | 0 | 17th December 2003 08:41 AM |
| problem with a data amplifier and laser supply | mIch | Digital Source | 4 | 17th November 2003 07:26 AM |
| Page generated in 0.06963 seconds (74.85% PHP - 25.15% MySQL) with 11 queries |
