| diyAudio Sponsor | ||
I just picked up a Jolida JD50A "passive preamp with remote control". I installed it last night and discovered that unfortunately it won't cut it. At max output it's barely loud enough for my requirements. It's fine for tv, but for serious listening I need just a touch of gain to make things happen. I previously used a 12SN7 SRPP preamp that sounds good and has lots of gain to spare.
The nice thing is that now I have a huge, nearly empty, chassis. Why let that go to waste? I immediately thought of converting it to a *simple* tube preamp so I could still use the remote but get a little gain. Here's what I have in my inventory:
The chassis is 2" high. My PT will fit no problem. The tubes can be mounted horizontially or I could punch holes through the top cover. My thoughts were a 12B4, 2C51, or 6922 circuit. I prefer to keep it simple and use a CRC filter. Either Tube or SS rect would be fine with me. Thanks for your comments. |
#2 |
There is great difference between the µ of 12B4 and 2C51/6922!
From what you say it does not seem likely that you should need µ of 30+; perhaps 12B4 is a good answer, but be careful as they are notorious for poor heater/cathode insulation which can make them noisy. If you use them, elevate the heater supply to say +40V, always a good policy anyway. Another factor is the length of the cable you intend to drive. Any more than a couple of metres (6') and you should be thinking of a cathode follower to drive the capacitance of the cable - your 12SN7 SRPP would manage this nicely as would 12B4 if you run decent current through it. A "Cinderella" valve that I like is 6S4; this has µ of 16, about half that of 2C51/6922 7N7
Plug them in and light them up |
#3 |
Go with the 12B4, the gain should be just right for your application. Theres plenty of people who have built the 12B4 line stage.
#4 |
7N7: My cables 3ft.
How about the 6H30p? I have a bunch of those. One tube would be fine then. Or how about 6h30 srpp? |
#5 | ||
http://www.ecpaudio.com |
#6 | |
7N7
#7 | |
Dude, I AGREE with the 12B4 idea. The low mu seals the deal. I'm attaching a schematic for your consideration. Ditch the PSU shown, but the signal circuitry will serve you well. Voltage double the 6.3 VAC winding of your power trafo with a pair of Schottky diodes. Use 2X 10000 muF. 'lytics in the doubler stack. Feed the resulting DC into well heatsinked (1 per 12B4) 7812 3 terminal regulator ICs. That 1 A./14 VAC winding can, with the addition of a small series resistance be used to power the heater of a Locktal based 14Y4 rectifier. Hold the value of the 1st filter cap. down, as you have more Volts than are necessary. A gyrator is a good substitute for a choke and has (in this case) the added benefit of dropping a few of the extra Volts. Oh yeah, since you are using a motorized volume control, eliminate the 100 KOhm pots. and install 1 MegOhm safety grid leak resistors.
Eli D. |
#8 |
Hi Eli,
I have two DN2450 units. Could I use one for each plate load? I read somewhere they aren't good on the plate unless cascoded. Does that mean they don't sound good, or they don't measure as "as good" as cascode? Also, what's the B+ for your circuit? I'm guessing ~250V?? With the PT I have would I be close with a 6X4 or 6CA4? I don't have 14Y4's but I have the others. Thanks. |
#9 |
Without cascoding, the impedance is mediocre and the bandwidth is limited. They're cheap. Do it right.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#10 | |
The pseudo choke I/P filter shown has the "fudge factor" cap. (initially 47 nF.) tweaked at the bench to make the B+ rail voltage, under load, come in at 120 V. 30 V. is enough compliance for a Bottlehead C4S. Why make the "sand" work hard and get hot? I suggested a LOW cost 14Y4 to keep the rectifier's heater supply separate from the signal tubes' DC heater supply. A 12X4 will do, but the 14Y4 is dirt cheap. Heck, the Locktal socket costs more than the tube.
Eli D. |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| LM4780 preamp Suggestions? | Wynand | Chip Amps | 13 | 17th January 2006 03:25 PM |
| GC Preamp Suggestions | Gcollier | Chip Amps | 835 | 10th July 2005 12:24 AM |
| Preamp suggestions | r0cket- | Solid State | 1 | 23rd September 2003 02:05 PM |
| Page generated in 0.12543 seconds (84.20% PHP - 15.80% MySQL) with 11 queries |
