Joel's 6SN7 preamp (photo) - diyAudio
Old 19th February 2003, 03:43 PM   #1
Default Joel's 6SN7 preamp (photo)
I just thought I would post a picture of a DIY project based on an excellent design by Joel. This is just a plain jane simple unit, no frills.
Joe
Old 19th February 2003, 03:55 PM   #2
Joel is offline Joel  United States
Joel's Avatar
Looks good Joe!
It's better than my own attempt at it - although I made so many changes to that unit it looked very butchered...
Old 19th February 2003, 04:50 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Default JOELS PREAMP.
Well done Joe.
Frank
Old 19th February 2003, 05:02 PM   #4
Its functional but does have a slight hum even after the pot was added. Like I said this was made on a budget with most parts being used. It won't take any beauty contests but I tend to like the performance. Many thanks for my questions that have been answered with patience and the help.
Joe
Old 19th February 2003, 05:22 PM   #5
Joel's Avatar
Default Hum???
Joe, I thought you had licked the hum problem? Is that audible in headphones, or speakers?
Like I said, mine does not hum at all, even when using the headphone jack.
Old 19th February 2003, 05:37 PM   #6
Joel
I thought I had the hum problem solved but I was wrong. The hum is there when using it with an amp, not headphones. The hum varies depending on the amp(solid state) I use.
Joe
Old 19th February 2003, 05:48 PM   #7
fdegrove's Avatar
Default HUM.
In that case it can't be the preamp's heaters.
It sounds like you have a groundloop somewhere.
Frank
Old 19th February 2003, 05:56 PM   #8
Joel's Avatar
Default Re: HUM.
Yeah. Frank is probably right.
Old 19th February 2003, 07:35 PM   #9
Default Mistake
I made a goof. I'm so used to using a butt set to trouble shoot audio that I forgot its not capable of going very low in frequency.
Yes, I have hum on the output of the pre amp.
The following voltages were taken at the tubes
12AY7
pin 1 120v, pin3 1.9volt pin
6SN7
pin 1 66volt, pin2 243volt pin3 85v
the voltages were taken with respect to ground with zero signal and input unshorted.
any ideas?
Joe
Old 19th February 2003, 08:02 PM   #10
Joel's Avatar
Default Re: Mistake
Originally posted by burnedfingers
6SN7
This is a problem. You have the 6SN7's biased at -19V at idle. Quite obviously you've made a wiring error.
The complete 6SN7 preamp Joel Tubes / Valves 103 14th March 2008 10:32 AM
Help with 6SN7 preamp tubedude63 Tubes / Valves 7 9th October 2006 12:31 AM
Joel's 6sn7 Round 2... Guiness Tubes / Valves 23 22nd June 2005 07:18 PM
More of Joel's preamp... Guiness Tubes / Valves 29 27th February 2003 12:54 PM
Copyright 1999-2017 diyAudio
