| diyAudio Sponsor | ||
Is anyone aware of a full wave vacuum rectifier with a forward drop greater than that of the 5Y3?
Eli D. |
#2 |
A 5Y3 plus a string of diodes?
http://www.ecpaudio.com |
#3 |
5R4 is like 63 or 67 compared to the 50 of the 5Y3 I beleive. I used them once when my B+ was a little high in a SET EL34.
"Make everything as simple as possible, but no simpler" Einstein |
#4 |
It's actually 67 @ 250mA
#5 |
Duncan PSUD has the 5Y3-G dropping 15 more volts that the 5r4-G for me ...
#6 |
I guess it depends on the load. My RCA handbook shows the 5Y3 dropping 50v @ 125mA, and the 5R4 dropping 67 @ 250mA. Are you actually simulating?
#7 |
5R4-G
#8 |
5Y3-G
#9 |
5W4 is about the same (45V drop at 100 mA), maybe a few volts more drop than 5Y3. But it's only rated for 100 mA maximum. The 5R4 drops about 30V at 100 mA, according to the curve on the data sheet.
#10 |
Thanks, Tom! The 5W4 is exactly the sort of thing I'm interested in.
A Heath AA-161 carcass that's already missing the O/P trafo is being converted into a full function stereo preamp. The 6.3 VAC filament winding of the AA-161's power trafo can power a DC supply for 2X 12AX7s and 2X 12B4s. Choke I/P filtering the "raw" AC should yield something quite suitable for driving a LR8 regulated 250 VDC phono section B+ supply. A gyrator after the initial LC section will dump some Volts prior to powering the line stage. Less IS more, when it comes to dropping resistors The 12B4s are CCS loaded at 20 mA. and an unbypassed 500 Ohm cathode bias resistor is used. I don't want to overstress the CCSes.
Eli D. |
| Rectifier question | ifeliciano | Tubes / Valves | 4 | 24th September 2006 08:26 PM |
| SD05 rectifier question | stef1777 | Parts | 1 | 21st February 2006 08:48 AM |
| Bridge Rectifier question | hotscot | Power Supplies | 14 | 15th January 2006 04:15 PM |
| hybrid rectifier question | dr.strangelove3 | Tubes / Valves | 17 | 4th October 2005 01:28 AM |
| Regulated vacuum tube rectifier cct. | Circlotron | Tubes / Valves | 5 | 14th May 2003 03:21 PM |
| Page generated in 0.09519 seconds (80.64% PHP - 19.36% MySQL) with 11 queries |
