diyAudio Sponsor
Old 8th December 2007, 11:34 PM   #1
Default 5814 Raytheon Windmill Getter late 50's
Any info on these tubes
I'm trying to assess what type of sound I should expect from these in comparison to the cbs hytron tubes
Old 8th December 2007, 11:53 PM   #2
7N7 is offline 7N7  United Kingdom
7N7's Avatar
I see you have recently joined the forum, so "welcome".
I do not wish to appear rude, but 5814 is just an industrial (i.e. ruggedised) 12AU7/ECC82.
I have made my views on this type clear in another thread here (which 12AU7?). I am sorry to say that whilst ECC82/12AU7 is fine in a VOX AC30 (I should know I have had plenty of VOX amplifiers in my time) but its distortion characteristics make it very unsuitable, in my view for hi-fi applications. 12AU7 produces a great deal of distortion, particularly 3rd harmonic which will most likely provoke what is known as listening fatigue.
If you are handy with electronics and a soldering iron, I suggest you re-jig to use 6CG7/6FQ7 as someone suggested on the other thread I mentioned
Best of luck
7N7
Plug them in and light them up
Old 9th December 2007, 06:20 AM   #3
Thanks for your reply
The 12au7 tube was going to used in my pre amp
I'm not a diy guy and pretty well stuck with this tube family
Old 10th December 2007, 05:20 PM   #4
kevinkr's Avatar
Since you are stuck with the existing topology, you might want to try some of the current JJ 12AU7A as they seem to sound better than most NOS USA made 12AU7A in hifi applications anyway.
I prefer the old French made Mazda ECC82/12AU7A to any made on these shores. Old German and Dutch Amperex are well worth a listen if you can find some for a reasonable sum. (Unlikely, but you never know.)
Without knowing anything about the equipment this is going into it is hard to know whether the advice fits the application.
www.kta-hifi.net
What the heck does a getter do ? bereanbill Tubes / Valves 4 17th May 2009 07:51 PM
Detached getter? rknize Tubes / Valves 6 25th March 2009 05:32 AM
6D22S Getter Question Ardee Tubes / Valves 5 27th September 2006 09:35 AM
DIY windmill steenoe Everything Else 33 30th May 2006 05:05 PM
5814/12AU7 Preamp? JojoD818 Tubes / Valves 15 13th April 2004 04:04 AM
Page generated in 0.07386 seconds (68.56% PHP - 31.44% MySQL) with 10 queries
