diyAudio Sponsor
Old 8th December 2007, 07:43 PM   #11
So
The output tube of the x-over could be powerfull enough to drive an output tube or phase splitter for a Pushpull output.
for the above case, as an example, you are proposing to include Xover functions between stages within an power amplifier? Such as our country fella Mathijs, from Machmat?
http://www.machmat.com/mysys/electri...es/kap2amp.gif
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 8th December 2007, 11:06 PM   #12
beamnet is offline beamnet  Netherlands
beamnet's Avatar
Send a message via MSN to beamnet
errr... no...
We were talking active crossover. So get any tubed active crossover schematic and instead of an output cinch fantasize a power tube instead. Maybe substitute the last tube in the x-over with a beefier tube to drive the power stage...
Old 9th December 2007, 09:19 AM   #13
Brett's Avatar
I see some issues with it.
- filters will need to be symmetrical
- a hefty driver will be needed
- all the output tubes will need to be the same; eg a 300B typically needs >60V for full output whereas an EL84 needs about 10V
- what happens when the grids go positive and current drawn
Better to biamp fully IMO. Select your designs and OPT's based upon the frequency range required and optimise. Seems to me like less compromise, and as you're 2/3 of the way to a whole second amp, do the job right.
Old 9th December 2007, 03:50 PM   #14
Sheldon is offline Sheldon  United States
I tend to agree that going all the way is the more practical approach, but hey, if we were practical we'd not use many tubes in the first place.
I would also think that filtering between output tube and OPT would be dicey. However, a single input and driver stage and multiple outputs is certainly doable.
To the issues cited:
Why would the filters would have to be symmetrical?
Yes hefty driver, or MOSFET follower(s).
Yes, easiest if output tubes are the same, but just need similar grid swing and plate voltage requirements - doable. Maybe single to multiple parallel tubes. As for grid current, either stay out of A2 or refer to previous comment.
Not surprised that George has wheels turning.
Sheldon
Old 9th December 2007, 07:52 PM   #15
Brett's Avatar
I assumed a PP O/P stage
No MOSFET followers here thanks.
Unless you have way more power than you need, it's not uncommon to find grid current on peaks in output stages.
3 way speaker with 1 order filters Hyldal Multi-Way 191 29th January 2008 06:29 AM
In the wrong place ? exurbia Multi-Way 12 24th May 2007 03:34 PM
Best place to buy DIY speaker parts? blake_mooney Multi-Way 10 5th May 2006 05:30 AM
I have a kind of UcD survey question, maybe it's in the wrong place... ptwining Class D 5 30th March 2006 05:33 PM
where to place active filters? AndrewT Multi-Way 1 22nd October 2004 12:14 AM
Page generated in 0.08986 seconds (76.55% PHP - 23.45% MySQL) with 10 queries
