Problem: attenuation after cathodyne and CF
Old 6th December 2007, 11:30 PM   #1
diegot is offline diegot
diegot's Avatar
Default Problem: attenuation after cathodyne and CF
I built the circuit attached but I'm having four times less voltage than the input at the output of the phase splitter and the CF.
The measured DC voltages are OK and I swapped the tubes and the problem persist, so I believe the problem is the circuit.
The +B is 140V.
Thanks for any help.
Old 7th December 2007, 12:05 AM   #2
On Hiatus
SY's Avatar
There are a pile of problems with that circuit. The distortion will be much worse than it needs to be. Same with balance.
As for the gain, I calculate about 0.9, so you probably have a wiring or measurement error. Are you measuring the gain just to one side or is that differential gain?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th December 2007, 06:05 AM   #3
lcsaszar is offline lcsaszar  Hungary
140V B+ is too low. I'd increase it to at least 240V.
Problem: attenuation after cathodyne and CFHide this!Advertise here!
Cathodyne Phase splitter simulation problem? wildswan Tubes / Valves 6 29th June 2009 10:33 PM
Cathodyne Questions dsavitsk Tubes / Valves 7 28th June 2009 07:36 PM
Can you use a MOSFET as a cathodyne aardvarkash10 Tubes / Valves 6 14th February 2009 11:11 PM
Cathodyne follower? :) mashaffer Tubes / Valves 6 16th February 2008 08:18 PM
Problems with cathodyne tAB Tubes / Valves 11 18th January 2006 08:31 AM
