diyAudio Sponsor
Old 5th December 2007, 12:43 AM   #1
Renron is offline Renron  United States
Renron's Avatar
Default Plug 'N' Play B+ time delay
Has anyone used this for B+ turn on delay?
If so what do you think of it?
Hook it up in series with the secondary B+ input. - or + side?
Is it a bad Idea to put one more piece of "sand" into the PS line?
Amperite Solid state delay relay
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 5th December 2007, 01:33 AM   #2
DHT112A is offline DHT112A  United States
I use them as a B+ delay in the CT of the power transformer. Use them in the AC power in and put a relay as the load. AC would be input and a relay to switch the B+ as the load. They work great but a small relay coil load may not trigger them properly so a resistor across the relay coil to increase the load on the timer may be needed.
B+ time delay relay cbutterworth Tubes / Valves 24 31st August 2011 12:53 PM
time delay with 2 amps? thedman Solid State 2 2nd November 2007 12:22 PM
2pole RC time delay? AndrewT Solid State 6 11th April 2006 12:23 AM
Battery Play Time Firebottle Chip Amps 0 22nd August 2004 01:46 AM
A plug'n'play EL34/KT66/6B4 SE amp SHiFTY Tubes / Valves 6 11th May 2003 11:33 AM
Page generated in 0.06225 seconds (69.79% PHP - 30.21% MySQL) with 11 queries
