I am looking for a very simple but good tube preamp. If possible, with only one tube per channel. No output transformer.
I would be happy if the preamp could be used as a headphone amp too. |
#2 |
diyAudio Senior Member
Frank |
#3 |
Maybe this one will work?
Anyone having some PSU recommendations? http://hjem.get2net.dk/aaholm_audio/schems/6dj8_1.htm |
#4 | |
Joel's schem Frank linked above would be better than the one you linked. |
#5 | |
The drawback is that you will have to use octal or novar types of dissimilar triodes such as a 6EW7,6GF7 etc. One of the triodes can be used for voltage amplification and the other as the poweramp part. If you need to keep things small then there is this one : http://www.diyaudio.com/forums/showthread.php?s=&threadid=10984 Cheers,
Frank |
#6 |
Frank,
You're right. I was thinking of a single triode/pentode per channel, not a dual in a single envelope. At a glance, the 6EW7 looks like a good possibility for a setup similar to Joels, ie CC->CF. Or what about a 6080 / 6AS7 SRPP? :-) Cheers |
#7 |
I think I give this circuit a trie
(I can build a headphone amp separate instead) http://hjem.get2net.dk/aaholm_audio/schems/6dj8_1.htm Its cheap and very very simple... perfect for a tube beginner like me. BUT I dont know which PSU I am going to use? |
#8 |
Years ago I made a little preamp...I call it my Experimenting Chassis because I have B+, heater and ground wires lead out externally for the breadboard...
![]() Drives a 5k load fine...not too much gain overall though, not with the tone circuits in. BTW if anyone was curious about the tone circuit in my 6L6GC SE amp, this is where I developed it. ![]() Mods I recommend: - Increased coupling caps. - Seperate cathode bias, and more bias (1k per cathode), likewise smaller plate resistors (circa 100k). - Higher voltage - a single, purpose-built transformer would function better than the current arrangement. If nothing else, a larger 2nd transformer and a voltage doubler. DC filaments if you feel adventurous...maybe a cathode follower output instead... Tim |
#9 | |
Hi Brett,
Either way, it won't have much gain to play with. Cheers, P.S. You are aware that most people want to burn off lots of gain,aren't you?
Frank |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Simple tube preamp? | picklgreen | Tubes / Valves | 10 | 11th February 2007 11:11 AM |
| Simple Low Voltage Tube Preamp? | CarlosT | Tubes / Valves | 11 | 1st February 2007 10:25 AM |
| The most simple tube preamp | timos_t | Tubes / Valves | 19 | 20th May 2006 06:23 AM |
| Newbie want to build simple tube preamp&psu!need help! | thomgun_lc | Tubes / Valves | 55 | 29th November 2005 02:08 PM |
